Guys,
I have done a lot of searching and reading but there is not much information reguarding results with GT** turbos, mostly discussion is about the HKS items.
I dont have a turbo I sold it as I was gonna do a rb25 turbo but i have decided to do the lot and have taken my car off the road.
I really want to hear your imput on the differences between the GT25/28 and different driveability. The GT25 is rated @ 400hp and I was told it will make 250kw@wheels, but @ what boost? I was looking for around 220-230kw@wheels to be daily driven and maybe wind it up a bit for the strip. I have a Wolf 3D V4 with hand controller.
To be able to fit the GT25 to my car I was quoted the following. $100 for the adapter plate welded to old manifold, $250 for 3" dump ($300) if i want a screamer and $220 for the lines(braided). Is this a good price? It was from Ricol Performance.
Any input would be greatly appreciated!
Thanx
Evan
P.S. I will have a cooler, fuel, etc to run the numbers... no comments on how its not just a turbo that will get me power :D
https://www.sau.com.au/forums/topic/19428-what-turbo-for-my-rb20det-buildup/
Evan,
I have only been in a RB20 with 2530, not 2835, so I wont comment on the latter.
the car in quesion put down about 230rwkw at 1.2 bar, came on boost quicly and pulled hard through to red line of 8200rpm. these turbos apparently hit peak efficiency at 1.5-1.7bar, so there would be a bit left. It was a drift car, so boost came on pretty hard.
With regard to fitting, the 2530 can come in a t3 form that will bolt straight up to a stock manifold (as it was on the above), so adaptor plate shouldnt be necessary. $250 seems pretty cheap for a dump. $220 for braided lines is pretty good to.
BTW, I have seen a 2530 second hand recoed, with polised comp housing and braided lines, wastegate, t3 flange for under 2k - which is cheaper than a high flow, and therefore IMO are pretty bloody good value for money.
yeh,
I think a 2530 would be great but I am a bit sceptical buying a second hand turbo from japan. There is one at hikari for $1780 with a t3 flange although in the pic I cant see hks on the turbo so i think it is a garrett item... anyone can confirm?
2530 sounds perfect for what I want and I would buy a second hand one if the condition was known.
Evan
Evan
i would go 2540.. if you want more hp later.. which im sure you will :D.. you could get a xtr or what ever equilavent and get them to build it to your specs.. the only real good thing about hks turbos over their garret base is that they come into their own world when boost is increased.. if you only wanna run 1.0 bar i would stick with something garret produce, the hks badge adds about 600-1000bux! you could get the same exhaust housing the 2530 uses (same size a/r ratio or what ever) and then put on a bigger compressor housing to get a quick boost response/spool up and with the bigger compressor housing it will flow a bit more at the top.. talk to a turbo specialist about your wants and needs.. you could end up happier..
water connections are usually pretty easy to souce, somewhere like enzed, or pritec? (i think). Without knowing what trim the wheel is, might be a bit hard to guesstamate.
What did they tell you it was capable of when you bought it? Did they tell you it is a straight fit?
i have opted to go with a gt25, i am undecided on if i should go the 400hp or 440hp model, i realise an adapter plate will be around $100. The 440hp model is only like $100 cheaper... but will be laggier? will the 400hp model support 250kw@wheels... i am undecided... i have been told the 440hp model will hit full boost around 3500rpm as i know someone who has one on a ca18 and it hits full boost at 4100rpm
thanx
evan
You will be pushing to be hitting full boost at 3500rpm.
A RB25DET turbo hits full boost by 3500rpm, you will be most probably be looking at the positive side of 4000rpm for full boost with any turbo that makes decent power on the RB20DET.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
