just rewmoved my bleed valve and need to go back to stock boost so i can drive the car... i have one hose coming from what is a pipe underneath my intercooler piping on the left side of the engine (facing the car's front end)... one from the intercooler piping itself and on form the turbo's actuator (i think that what the gold drum thingy is)
and i have the stock boost solenoid which has two connectors and electrical wires coming from it.. so where does each tube go.. dont want no overboostin lol
cheers...yup that helps lots. Is useful i think for others too who might not know what it is ;)
Are those wires blue w/ white stripe and white? I have an orphan plug sitting around, just wondering whether its the same one. Does it require power or is it fully neumatic?
hmmm.. well i have the solenoid in place.. From those photos it appears the bottom hose from the solenoid is going to the wastegate, where as the top hose is to the throttle intake? So all should be fine right?
Unfortunately its not, when i connected it like that infinite boost..it just kept going up and up until about 12psi till i backed it off ;)
There is also a blocked outlet on my (stock) BOV return pipe where it goes back to the turbo, so maybe the top hose is meant to go there? Although the pressure should be pretty much the same shoudlnt' it and make little difference?
I mean i can "cheat" and just connect the intake direct to the wastegate and it will hold correct boost (which i'm doing for running around) but its for an EPA so the solenoid needs to be connected (i think?)
Anybody ?? Quicksmart? if anybody has a standard boost solenoid can they jump out to their car and have a close look plz?
Hi,
The bottom line on the solenoid goes to the T piece that in turn goes to the wastegate actuator (where your bleed valve probably is).
The top line on the solenoid goes back off into the BOV return line. As I recall, it's under the air piping that leads into the turbo inlet.
The striped wire (to the right of the plug) is a constand 13.5 volts
The solid colour wire (the left of the plug) is a negative trigger controlled by the ECU to open the solenoid.
The solenoid is fully electric.
line goes from high pressure side of the intercooler to the waste gate, then a "t" piece, the "T" peice runs a hose the the boost control solenoid, then from there to the hose that runs from the standard BOV to the low pressure side, (between turbo and AFM).
ok.. well i got it all sorted the other night..the key is the t-piece between the intake side and the wastegate - the stock solenoid hangs off that, and its different to my EBC configuration where it sits in between. Now rises to a solid 7psi
In the aid of providing a useful resource, i've posted a couple of pix of how I installed it
All was inspected and passed by the EPA correctly :D
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
