I found this website www.photoblocker.net.au they sell this spray that so post to hide your number plats when the cops take a picture for your car the flash reflects back so you will never get speeding fine
Has any one have it and tried it does it work. ive posted on many different forums if any one has any useful info i will post up here
https://www.sau.com.au/forums/topic/194296-photoblocker/
from memory there was a discussion on here about it, maybe on another forum, but think it did work, only one way to find out.... run a red with someone else's plates on your car and wait for them to bitch about getting a fine lol
https://www.sau.com.au/forums/topic/194296-photoblocker/#findComment-3484305
Myth- busters took all the products on :no:
By memory none worked ....
The new digital cameras using software can by-pass most films or sprays on the number plates..
Yeah...try it with some-one elses number plates... :laughing-smiley-014:
How are you to know if he gets booked..ask him or her :wub:
https://www.sau.com.au/forums/topic/194296-photoblocker/#findComment-3484332
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
