Advance Orders For Nissan Gt-r Exceed 2,200
the way i read that press release was that the pre-order number was talking about the number of orders placed WITHIN Japan??? It didn't seem to mention 'world-wide' pre-orders??
Or did i just read it wrong
how many GTR did they say they gonna produce a month or a year?
Ive read somewhere that Nissan is setting a limit of 1000 units per day, so there wont be oversupply to the market this will ensure that resale value is kepted high because of the demand, which will be an advantage to the new gtr owners.
..............................LOL?
I think you will find its 1000 units per month. not per day.. 1000 units per day equats to 365,000 GT-R's a year, and over its life time 2,555,000 GT-R's.
Thats alot of GT-R's :D
Thats alot of GT-R's :banana:
Yes that would be more correct. Apparently they are built by hand so knocking off 1000 a day might be a bit extreme...
Yes sorry 1000 units per months sounds more like it, thanks for correcting me.
Yup, 1000/month is the initial production target according to Steve Lague, Motoring section West Australian Saturday Dec 8/07. The way I read the article Australian Nissan dealers are holding orders for 2900 GTR's (not available before 3rd qtr 2009) from Nissan Japan, market depth in the USA & UAE who/which countrys are ahead of Australia in the delivery queue have yet to be tapped?
Cheers GW
Are you saying OZ alone has made 2900 pre-orders???!! :w00t:
I'm 99% sure the article was JUST referring to domestic orders, and that's it.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
