Hey guys I was bored so I decided to whip this up.
"Fast" is the name of Nissan's Database for finding part numbers for your car when you go to the dealership.
You can enter any Nissan Vehicle Vin number into fast and it will tell you the production month, date, paint code, inteior trim etc etc and all of the options your car came out with provided you have installed the appropriate libraries. They are generally broken up into Australasia/Japan/Europe and America.
For the protection of this forum I won't provide links to the Nissan Fast download however it is easily found using a search engine / torrent site.
Onto the good stuff.
  1. Once you have installed "Fast" (instructions come with download) open it and you are presened with the folowing window:
  2. Enter your vin number as shown:
  3. Hit enter or OK and you should be presented with a screen that looks a bit like this:
    As you can see this displays a whole heap of information about your car.
    Now lets search for some parts.
  4. Click here:
  5. And you should get this:
  6. After you've made your selection(s) hit ok and you'll make it to the group index:
  7. Pick the section you want (right-click to unselect if you need to) and hit OK to get this:
  8. Now lets get our specific parts. If you click a part code once, it turns blue and you can see the description; click it again, and it turns red and adds one to your selection list. Keep selecting the parts (if you need) and previous selections appear in green.
    You can see in the above illustration theres is an option in the lower left corner to increase you're quantity. Now you can close this window and go back to the main FAST window. When you do, you will see that only the part code and description are listed for each item you've picked.
  9. Hit the p/no search button on the toolbar to get your full part number:
  10. Bingo! Take that number off to Nissan and Your set.
  11. Wait a few days And you get this!
Edited by MintR33
  • Like 2
  • 2 months later...
  • 1 year later...
Not sure if this is right thread to ask, but I thought I'd ask.
I've got FAST, which one of files for Skylines? (a1, a2, a3, b1, b2) and is there a thread on how to install on computer (yes I'm dumb).
Any help would be great.
Thanks
I did upload FAST to some web mirrors, but I don't know if they're still up (instructions in the link as well)
http://www.skylinesaustralia.com/forums/VI...;gopid=4277147#
a1, a2, a3, b1 & b2 is all skylines (up to 2001 if you have the version everyone has)
Cheers for your help, might have to get my mate to attempt to install it for me (yes i'm really that dumb!!).
Back to the tutorial, very handy.
Cheers
Yeah it works great , i just want to ask ,if your looking for parts on a different model and you dont have a vin number what do you do then.
i.e i have a R34 GTT but im looking for BNR 34 parts also how can i do this ( i tried the parts master but i need numbers to input , i need to use fast so i can see image of part as well.
for those interested - I have the 2009 ADM disc here. I would like the USDM one if its out there. it would make looking up G35 stuff a LOT easier for me.
To search for parts without a VIN simply type the series your interested in into the 'Model Series' field (see first post above), then hit return and wait. After awhile you should see that the 8 (ie 2 rows of 4) buttons immediately below the model series/Prod.M/Y fields become available to select. If you click on each in turn you'll see that they are now drop-down boxes, which allow you to select the various broad model options available for that series. For example, one drop-down will show all the engines available for a particular model series; another will show transmission options and another will show 2DR/4DR type, etc, etc.
So in your case simply type in R34 to 'Model Series', press return, wait, then select RB26DETT engine, 2Dr, Hicas, etc, etc. You can then search for the parts as described above. Note that if Nissan made changes to parts within the model series (ie supercessions), when you eventually come to select the parts you are interested in, the FAST system will ask you to make a choice about the month and year of manufacture of R34. At that point you will have to make a bit of an educated guess about which way to jump, although the FAST system will also show you the supercessions.....if you know where to look.
  • 1 month later...
Some other handy tricks.
If you're having no luck finding a part, in the main screen hit F7 which will bring up a description search box. You can only have one word in each box.
Also part codes and sections should stay the same between models. For instance, an air filter part number will almost always start with 16546 and be in section 165, not matter what vehicle. So if you're using it regularly this can be a faster way to find what you need.
  • 4 years later...
bit of a dead thread, but the versions i can get my hands on seem to have the aus and nz models missing, its the same with alot of the other parts interpreters that i use and i know you don't need it as our stuff is imported but it would be good to be able to do aussie cars too.
anyone know where i can get them?
  • 1 month later...
I am not sure being an old thread if I will get a response, but I am chasing the part number for a BOV gasket and the bulb holder in the A/C unit.
Two photos of the bulb holder attached.
Thanks in advance.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
