I have an R33 GTS that has been written off due to being t-boned. Although the car is not worth getting fixed the damage is not actually that extreme and only the rear quarter panel and suspension has been taken out. All the rims are still okay and everything else inside and out are in good condition.
Anyway looking at $4500 ono for the entire car as is...
Edited by MSPEC
https://www.sau.com.au/forums/topic/194345-wreaked-r33-gts-1995-s1/
How many KM's has the car done?
I have money ready to transfer for gearbox delivered to SA
Not sure about ks will have to check. Looks like I am going to have to pull the car apart. I will arrange to get all the parts removed asap.
Hi there, any chance youve still got all for springs for your ride. If so how much would you be will to part with them. Also, i take it, from the pics, that they havent been compressed/lowered previously. Kind regards, Evan
does it run and how many ks has it done let me know
might be good for project car i am looking at building
The engine runs fine but the rear right hand suspension is fooked.
128000ks on the clock. The car itself is in great condition inside and out (with the exception of the crash damage). The car was fully re-sprayed a year ago.
Edited by MSPEC
4 stud hey
umm i know the suspension and panel at the back there are pretty bad
but are the mounts for the suspension at all dammaged??
and is it posible to transefer suspension from a 5 stud s1 gtst into this car??
4 stud hey
Not sure I am no expert on this kind of thing ... you would have to come and inspect the damage yourself.
well i will look into it
what would you want for the bare shell
no lights no doors no boot no front guards no bonnet nothing just the bare shell
Not sure I am a while off getting that far but what ever it is worth I guess.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
