got an r34 auto that planning to get a stage 2 shift kit. just curious if anyone knows where i can get one installed in melb. or if theres anyplace that is willing to order one from mv in adelaide and install it for me. cheers
Edited by john-e boi
i had my valve body modified by MV auto aswell.
i took my car to J&P Clayton Automatics where they removed, packed and shipped the unit to adelaide.
and then MV shipped it back to J&P to have refitted to my car. total turnaround was exactly a week.
the guys at J&P were pretty good. i'd definitely go back there again if i needed anything.... so give them a try.
29 Garden Rd, Clayton. T: 9574 1140
thanks for that. so was your car off the road for a week? left your car there? how much was it all up?
yep, car was off the road for a whole week.
well...
MV Auto shift kit (incl shipping to and from Adelaide) $384
"Davies Craig" oil cooler $117
J&P Auto's - Remove/replace valve body, service of transmission (incl flush oil, new filter + gasket), and fitting the oil cooler $346
as mentioned above, check the other section of the forums as this has been discussed in alot of detail - but definitely get the service done aswell, and if u wanna play it safe get an oil cooler for the transmission oil aswell.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
