Hey GTST I had the same prob, I considered a tow bar for mine but it looks crap and the quotes to put one on rediculous
Buy a mountain bike where you can take off the front/back wheels and the seat and it'll fit
and about r32/r33 i agree with the guy that said be grateful because I reckon without them you'd all be in commodores
how about a 10yo commo vs 10yo skyline, now thats a real one sided argument
I can't be bothered doing that twice a day 5 times a week.
Most I'd be wiling to do is remove the front wheel which is quick release anyway.
but in a 180, I don't need to.
  • Replies 213
Is it me or does R32 owners get majorly defensive and just has to bag out the R33? I've noticed it with this thread and every other thread where its R32 vs R33... is there something to prove to us R33 owners? :)
mm well seeing as the actual topic is questioning/challenging the cost of the r32, of course there will be people discussing/defending it? if we started a thread about r33's being shit there would no doubt be a similar defensive attitude which you seem to be exaggerating is happening here
All Skylines are beautiful machines. If you think the price is too much for a R32 then take your money elsewhere. That's why we have our own brains, money and make our own decisions. Up to you mate, but at least your'e in the right shopping centre, and not at the bored or :) commonwhore dealership. Happy motoring! LOL
I'm not exaggerating it... I love all R32/R33/R34 alike they all have something about them that I like. But most threads that I go through that has something R32 vs R33 I usually see the same yadida as this thread - its not a fact but its from what I've noticed browsing around.
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
