Wow this thread is still going from before I bought my R32 GTSt. And that was almost 5 years ago now!!!
I paid $16.5k back then for the absolutely cleanest one I could find, probably looked at over 15 or so before seeing this one.
Now its 5 years later, 100,000kms more and its still going strong. Never had a problem.
But I guess now with 175000kms on it and being 15 years old I'd expect to be able to sell it for about $11k. I'd think it would sell pretty quickly for around $10k. I wouldn't think anyone would pay over $15k for an R32 gtst now, not when for a few grand more (say $20k) you would score a decent R32 GTR.
  • Replies 213
Fools, while you all fight amongst yourselves you forget the real enemy...
To the general public, we get boxed in the same category as the rest of these losers
guy on the left isn't a loser, i think its hilarious! he did it for his year 12 formal
spent a lot of planning and time on it (there is a thread about it somewhere)
the first is a practical joke in oz, and the AE86 is a car that was made for an ad that makes fun of ricers.
sshhhut uuuppp rooyyyy...
The purpose of this thread was a little bit of a "knock" on R32 owners and a little bit to find out why the price has stayed high.
but it became obvious VERY quickly that some R32 GTST owners have very small penises.. and their virtual penis extention of a car was knocked and the Napoleon in them came firing out.
AND Still, there are some firing up.
A little too passionate about your choice I'd say.
But it's true.. it doesn't matter than the R33 is a better performance package than your cars.
so you don't need to worry that they have more potential and a better base to begin with at a better price.
None of that matters. :wave:
Roy - I do like your car.
I am willing to give you a sister in law for it.
it's my wifes identical twin so you know she is of top quality. :(
The rest of you EMO R32 GTST owners should have a coke and a smile and shut the f**k up
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
