(just re-read the first page) im just a little skeptical that the old shitter T04e would rack out 400rwhp… especially dropping to .9 bar
I had one of the largest variants in a .82A/R rear (and a few people i know had similar turbo specs years ago) and it was no more than 240rwkw at best with 13-14psi, and best mph of 112-113
I mean, if you have a fairly mighty MPH around the 120+, then fair enough.
Not trying to take the thread further off course, I just find 60rwkw a bit much to take for identical setups bar ECU. That could be one reason your motor is together :)
Anyways, when you see the RB26's fail with say, what, 350rwkw doing circuit work. RB25's go down the near enough same road.
As an example, you could make 350rwkw and run it daily as a street car, but fact of the matter is your never going to see much past 120km/h for longer than a second or two… And the motor is hardly going to see 350rwkw on a daily basis now is it?
People saying that’s the case are kidding themselves. Also remember motors running like this are under nowhere near the stress that a motor doing weekend track work would see with regular expeditions into the 200km/h+ zone and sitting well up in the RPM scale at the same time, for a long time.
I reckon you probably could have a motor crank out 350rwkw. But would it be reliable? Depends on the situation and most likely not forever.
Max power and reliable power are different.
If a motor can run 350rwkw for 5+ years…and by that I mean seeing 350rwkw daily on a factory bottom end, I'd be surprised.
I agree totally.
When people compare how long an engine has lasted they really need to take into account what the vehicle is used for.
I have busted 2 x RB25's on the track with 280RWKW @ 1bar. They both lasted for about a year before letting go.
I am sure (know for a fact) that they would have gone strong for lot longer if the car wasn't almost purely for trackwork. I have all the support mods and a very very safe (read power compromising) tune on low boost but the kind of stresses that they have to put up with on the track is just asking too much from a 15yr old factory engine.
  • 9 years later...
Pretty impressive power for an engine with no crank, no pistons and no rods.
With good enough turbo and supporting mods you dont need them. On a high powered engine the oem ones are the weak-link anyway so better get rid of them straight away
[emoji85]
4 minutes ago, Chris90 said:
Yes everything bolt on.. Fuel pump, injectors, garret turbo, intercooler, front facing plenum, exhaust, haltec system, 6 boost manifold, turbosmart eboost... Just the basic.. hahahaha
wow $20K spent on bolt ons and keep an "un-opened" motor - is that just for bragging rights?
Neo motors are stronger than R33 RB25s "out of the box" so that's the way to go in this context.
As other's have said above, "it's all about the tune" to keep the motor safe (safe-ish) at those HP figures - and running E85 (E87? I don't know what that is?) as you've done is the way to go for ethanol's resistance to detonation.
Impressive horsepower - well done!
cheers
Mike
A different perspective is my recent experience, where even with minimal horsepower (~205 KW), a bad tune and tuner wrecked my bottom end.
It was never a good idea to slap a NEO head onto an R33 bottom end, but 2 workshops (the 1st workshop put the head on and dyno'd it, then another did further work and dyno'd it) never mentioned anything about not putting a NEO head on an R33 bottom end.
2 years later and the compression across the cylinders was all over the place and the bottom end was wrecked. Probably less due to tune than tuner - but they go together.
The cautionary tale is that these engines (any engine) can be damaged with poor tunes and tuners - even at modest horsepower.
@Chris90 and many others have shown that the standard RB25 can take significant horsepower when tuned well.
In Chris's case - he knows he's pushing the boundaries - well done - after all if one pops he just sources another!
cheers
Mike
one i did,  basically a standard budged build rb25,  i think the whole car owed the guy under 6 grand
standard intake and exhaust manifolds
the car lived on limiter and it lasted a whole 2 months of disrespectful abuse before it broke a rod
the car still ran with the broken rod handing out the side too lol
  • Like 1
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
