(just re-read the first page) im just a little skeptical that the old shitter T04e would rack out 400rwhp… especially dropping to .9 bar
I had one of the largest variants in a .82A/R rear (and a few people i know had similar turbo specs years ago) and it was no more than 240rwkw at best with 13-14psi, and best mph of 112-113
I mean, if you have a fairly mighty MPH around the 120+, then fair enough.
Not trying to take the thread further off course, I just find 60rwkw a bit much to take for identical setups bar ECU. That could be one reason your motor is together :)
Anyways, when you see the RB26's fail with say, what, 350rwkw doing circuit work. RB25's go down the near enough same road.
As an example, you could make 350rwkw and run it daily as a street car, but fact of the matter is your never going to see much past 120km/h for longer than a second or two… And the motor is hardly going to see 350rwkw on a daily basis now is it?
People saying that’s the case are kidding themselves. Also remember motors running like this are under nowhere near the stress that a motor doing weekend track work would see with regular expeditions into the 200km/h+ zone and sitting well up in the RPM scale at the same time, for a long time.
I reckon you probably could have a motor crank out 350rwkw. But would it be reliable? Depends on the situation and most likely not forever.
Max power and reliable power are different.
If a motor can run 350rwkw for 5+ years…and by that I mean seeing 350rwkw daily on a factory bottom end, I'd be surprised.
I agree totally.
When people compare how long an engine has lasted they really need to take into account what the vehicle is used for.
I have busted 2 x RB25's on the track with 280RWKW @ 1bar. They both lasted for about a year before letting go.
I am sure (know for a fact) that they would have gone strong for lot longer if the car wasn't almost purely for trackwork. I have all the support mods and a very very safe (read power compromising) tune on low boost but the kind of stresses that they have to put up with on the track is just asking too much from a 15yr old factory engine.
  • 9 years later...
Pretty impressive power for an engine with no crank, no pistons and no rods.
With good enough turbo and supporting mods you dont need them. On a high powered engine the oem ones are the weak-link anyway so better get rid of them straight away
[emoji85]
4 minutes ago, Chris90 said:
Yes everything bolt on.. Fuel pump, injectors, garret turbo, intercooler, front facing plenum, exhaust, haltec system, 6 boost manifold, turbosmart eboost... Just the basic.. hahahaha
wow $20K spent on bolt ons and keep an "un-opened" motor - is that just for bragging rights?
Neo motors are stronger than R33 RB25s "out of the box" so that's the way to go in this context.
As other's have said above, "it's all about the tune" to keep the motor safe (safe-ish) at those HP figures - and running E85 (E87? I don't know what that is?) as you've done is the way to go for ethanol's resistance to detonation.
Impressive horsepower - well done!
cheers
Mike
A different perspective is my recent experience, where even with minimal horsepower (~205 KW), a bad tune and tuner wrecked my bottom end.
It was never a good idea to slap a NEO head onto an R33 bottom end, but 2 workshops (the 1st workshop put the head on and dyno'd it, then another did further work and dyno'd it) never mentioned anything about not putting a NEO head on an R33 bottom end.
2 years later and the compression across the cylinders was all over the place and the bottom end was wrecked. Probably less due to tune than tuner - but they go together.
The cautionary tale is that these engines (any engine) can be damaged with poor tunes and tuners - even at modest horsepower.
@Chris90 and many others have shown that the standard RB25 can take significant horsepower when tuned well.
In Chris's case - he knows he's pushing the boundaries - well done - after all if one pops he just sources another!
cheers
Mike
one i did,  basically a standard budged build rb25,  i think the whole car owed the guy under 6 grand
standard intake and exhaust manifolds
the car lived on limiter and it lasted a whole 2 months of disrespectful abuse before it broke a rod
the car still ran with the broken rod handing out the side too lol
  • Like 1
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
