WYTSKY Posted November 20, 2007 Share Posted November 20, 2007 Hey guys, I have a question regarding the atessa 4WD computer, A cuple of weeks ago an old lady went up the back of me, didn't do much damage to me, just a broken rear bumper... little bits... then about a week later I was just driving normally when my abs and 4WD light came on, don't know why, feel as though it was related to the crash.... now, every 2 days or less I will be doing nothing out of the ordinary and the warning lights will just come on... I pull over, wait for 5 minutes, turn on the car again and it seems to be fine for a little while. My tuners believe it has something to do with the computer, not the reservoir in the boot, because I checked it and it is appears fine, so I am looking for a new computer...(IF YOU GUYS HAVE ANY OTHER EXPERIENCES WITH THIS PLEASE POST) however, it is extremely hard to find a gts4 atessa computer, instead a GTR's one is easier to find, but I know they have their differences, for eg. the GTR has an atessa pro system running and a gts4 has just got an atessa... Will it make a difference if I used a GTR one? Thanks for your time. Adam Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/ Share on other sites More sharing options...
funkymonkey Posted November 20, 2007 Share Posted November 20, 2007 R32 or R33 GTS4's as they're a lil different. in the R32's the GTR's and GTS4's were quite similar but not so in the R33's. Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/#findComment-3485871 Share on other sites More sharing options...
WYTSKY Posted November 20, 2007 Author Share Posted November 20, 2007 Oops.. forgot to say an r33 s1... and if it makes a difference I recently turboed the car as well.. Adam Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/#findComment-3486369 Share on other sites More sharing options...
paulr33 Posted November 20, 2007 Share Posted November 20, 2007 the 4wd / attessa system copies a few signals from the main ecu and they get relayed to the ECU in the boot so passenger foot weel = main car ecu boot under parcel shelf = 4wd / abs / active lsd computer the main signals are speed, rpm and TPS TPS is probably the main one as at car bootup if TPS is not present (to the 4wd computer) it will fail and give up also if TPS goes out of whack at runtime then it will give up the ghost. check and trace the TPS wire or make sure your TPS wire at the 4wd computer has voltage at idle should be around 0.33v ish give or take. Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/#findComment-3486966 Share on other sites More sharing options...
WYTSKY Posted November 20, 2007 Author Share Posted November 20, 2007 Thanks for the help, but I have a few questions... what does TPS stand for and what does it do? when you said "goes out of whack at runtime then it will give up the ghost. " you did mean while driving yeh? because it doesn't come on straight away when I turn on the car.. could take an hour.. a day... one thing that is strange though... whenever the abs system and 4wd system fail I can tell without even looking at the warning lights in the dash cluster because I feel it in the brake, feels like a lil lump for a second... finally, if I got out a multimeter and checked to see voltage... what color would the wire be and Im assuming I would have to check when the warning lights come on? OH.. one final thing... it may be related, but i'm not sure, I have one of those atessa controller things where you can set how much distribution of power to front or rear... I have never touched it in the past few weeks... (been too bloody dry to need it) ... could this have something to do with it? Thanks again for the help, Adam Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/#findComment-3487082 Share on other sites More sharing options...
R31Nismoid Posted November 20, 2007 Share Posted November 20, 2007 ATTESSA is more driveline dependant - moving to that section as it isnt related to turbos/motors. cheers Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/#findComment-3487229 Share on other sites More sharing options...
paulR32gtr Posted November 20, 2007 Share Posted November 20, 2007 (edited) TPS = Throttle Position Sensor - attached to the throttle butterfly - throttle body on the engine Edited November 20, 2007 by paulR32gtr Link to comment https://www.sau.com.au/forums/topic/194480-atessa-computer-gts4-or-gtr/#findComment-3487258 Share on other sites More sharing options...
