Mentioned this in another thread but thought i'd make a thread to see if anyone else was interested to save on postage costs.
Basically this guy (Harold) sells Mobil, NGK, Redline, Royal Purple and Castrol products online at cheap prices for a set postage rate of $25 per box, each box can fit about 12 quarts . So i was wondering if anyone wanted to group in for any items to save on shipping.
Price List (oil prices are per quart (Quart = .95L):
Mobil:
Mobil 1 0w40 - $11.99
Mobil 1 10w30EP - $12.99
Mobil 1 15w50EP - $12.99
Mobil 1 Synthetic ATF - $12.99
NGK: (check site for necessary plug)
NGK Iridium IX - $12.50 per plug
NGK Platinum G-Power - $10.00 per plug
Redline:
Redline Engine Oil - $19.99
Redline Gear Oil - $20.99
Redline Manual Transmission Oil - $20.99
Redline Shockproof Gear Oil - $20.99
Redline Automatic Transmission Fluid - $20.99
Redline SI-1 Fuel System Cleaner (444ml) - $19.99
Redline Water Wetter (355ml) - $20.99
Royal Purple:
Royal Purple Engine Oil - $19.99
Royal Purple Gear Oil - $18.99
Royal Purple Synchromax Manual Transmission Fluid - $18.99
Royal Purple Max ATF - $16.99
Castrol:
Castrol SYNTEC 0w30, 5w40, 5w50 - $11.99
Majority of the oil prices are around $15 cheaper per quart so instead of paying $90 for 5L of Mobil oil you can buy the same amount for around $50
Website: http://www.performancelub.com/index.htm
A lot of good reviews by other Skyliners can be found in the the later pages of this thread - http://www.skylinesaustralia.com/forums/go...ils-t22458.html
So if your interested just post here with what you want and we'll go from there.
https://www.sau.com.au/forums/topic/194529-need-oil/
Speaking of Oil, just had a look for some shockproof Redline Gearbox oil, for a big 4 litre bottle is 140 ish dollars, is that roughly around the right price? Happy to pay that much, but bit concerned to make sure thats the rrp.
https://www.sau.com.au/forums/topic/194529-need-oil/#findComment-3490967
I'll put in for a Redline Shockproof 2.5L and a Motul 8100 Xcess 5L if you can get them cheap.
No Motul sorry, only whats up above, Redline is fine though.
Will be sending the order out this Friday if anyone else is up for it.
https://www.sau.com.au/forums/topic/194529-need-oil/#findComment-3499125
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
