  • Replies 59
Posted Images
hope to own a gsxr 1300 by than ^_^
Don't do it......I used to have a GSXR years ago and almost killed myself when an 81 year old female in her Datsun 1600 wiped me out.......too much power for 2 wheels anyway.
If I hit a car with my current 2 wheel steel horse, it'll just push the car out of the way, unlike the lightweight GSXR.
go a hayabusa (turbo) they look mad when done up right
i thought the sled would slice through the car instead :P
don't usually like those sorts of bikes but that 1s tough :spank:
is the bike quicker than the GTR?
Haven't had either very long yet so I'm not sure.
I've never really hammered either of them yet apart from a few short bursts here or there.
Bike's got a 100ci (approx 1630cc) engine. Unlike the high revving Jap bikes, its more of a torque monster and alot heavier than them.
judging by the seating position on the bike, sustained high speeds would tax ur arms somewhat cos u'd sit up and effectively be a parachute... could prove hard to hang on. Don't have farings (spelling?) to hide from the wind. no doubt that tourqe monster would have a whole bunch of get up n go, accelerating at an alarming rate would be no hassle :)
just my 2c
Yeh Carl, ur pretty much on the money there. The bike was designed to be a show bike and a weekend cruiser so it's not goin to do a 1/4 mile in 10 seconds......having said that, it's torque that gets you across the lights and this metal monster has plenty of that.....it'll tear up bitumen with that big rear!
And ur right, that seat height is low......about 6 or 7 inches lower than the lowest Harley including the FXDL Dyna Low Rider.
yeah Pete, designed as a show bike but no doubt it hauls ass
i reckon it would leave me sitting at the lights scratching my head :)
for 1600odd cc's that'd have huge torque for what about 200odd kilo..... my old man has a Vulcan VN1500, a Harley lookalike basically, thats a 1500cc and a fairly quick bike for 300plus kilo!
Not bad at all for a water cooled.......would be a great cruiser on a long run.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
