I am keen on buying new rims, but need to know what is the widest i can go.
I know that 19x9.5 will fit on the rear of my R33 GTST
But
The same rims also come in 19x10.5. Given the right offset, will these fit under the standard 33 GTST rear guards, without hitting/rubbing on any suspension components, inner guard, etc? If so; what is the right offset?
The height from center of hub to arch is 340mm (unloaded) and the guards have been previously rolled (not flared). I am NOT willing to make any more modifications to the guards, just want to know if 10.5" wide rims would bolt straight up, without any hassles. Obviously with 10.5" rims, i'll be running 275 or 285 tires.
Your help is appreciated
https://www.sau.com.au/forums/topic/194562-will-105-wide-rims-fit-at-the-rear/
Maybe to close to call there, all depends on the offsets. I have 18x10's with a +22 offset i think and i need to get the guards slightly flared for them to fit under without munching the guards, so it will all depend on the offset dude... mine had 265's on them aswell
Edited by Weapon
even 9.5s are pushing it especially in 19s...10.5s no matter how you play with the offsets you may encounter scrubbing at either side...too low an offset will rub ur guards...to high an offset will probably rub ur suspension...
Tis true, i have about an inch maybe more clearance between the coilover and the inside edge of my rim... but it also sticks outside the guards by that extra inch lol
Thanks all! Looks like i'll stick with 19x9.5 and 265 tyres.
why dont you want to work the guards ?? its cheap and easy!!
man up and do it.
I have a 3-layer pearl red paint job (similar to Candy Apple Red), and do not fancy respraying the whole car just for rims ;)
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
