Hi,
just wondering, r32 come with centre locking? my r32 doesn't or not working! how can i check it?
cheers
Generally they do have central locking controlled from the drivers door but not keyless entry.
You can add a slave in the passenger's door so you have keyless entry if you wish.
If you lock the drivers door and the passengers door locks then you have central locking, if it doesn't then you dont have it/it is broken.
Pull the door skin off the drivers door and see if you can spot the actuator, if its there then its faulty/broken so will need replacing :verymad:
https://www.sau.com.au/forums/topic/194563-centre-locking/#findComment-3487525
Pull the door skin off the drivers door and see if you can spot the actuator, if its there then its faulty/broken so will need replacing :)
thanks mate,
I took the door panel off both sides, the driver door has actuator but the passenger door does NOT have it! there have the wiring with the plug hanging around where the actuator suppose to be.. How can i test it if that wire is for the actuator for centre locking? does centre locking has fuse? and where ?
Cheers
https://www.sau.com.au/forums/topic/194563-centre-locking/#findComment-3489401
There have the wiring with the plug hanging around where the actuator suppose to be.. How can i test it if that wire is for the actuator for centre locking?...
Maybe you could tell with a test light, or multimeter in the plug end. Activate the central, and see if you get a signal out of the plug.
https://www.sau.com.au/forums/topic/194563-centre-locking/#findComment-3498955
no. i do get any signal from the plug.. where else should i check then? are there suppose to have any motor or actuator in the door for centre locking?
cheers
https://www.sau.com.au/forums/topic/194563-centre-locking/#findComment-3500965
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
