Make: Nissan
Model: KRPS13 (180sx), minus the K because hicas is locked. :verymad:
Milage: 120,00 on chassis, 20 thousand on new engine.
Transmission: 5 speed manual
Colour: black
RWC supplied? n/a
Currently registered? sure is
Price: 14k-Neg.
Contact: Tim-Via this thread, pm or mobile 0407795149
Comments / Modifications:
time to sell the 180 and get something different.
heres a run down; i bought it stock and have done all the mods myself, apart from the obvious stuff.
1991 180SX-sunroof model
5 speed manual SR20DET
Rebuilt with forged pistons by Chris Milton Engines-receipt included.
Full 3 inch turbo back mandrel bent exhaust with hi flow cat and stainless steel muffler-receipt included-still with warranty
FMIC
Brant AA02A alarm with triple cut, glass break sensor, battery back up siren and 2 remotes-receipt included
Turbotech boost controller-set at 12psi
Rear Tein coilovers. stock struts included.
Locked hicas, with lock bar and all lines and hicas pump removed all the way to the front-done properly, not looped back at the rear of the car, hicas light has been disconnected, but will still come on if power steering level is low. like i said, done properly.
Rear strut brace.
Speco 2 inch boost, oil press and water temp gauges.
turbo timer-not installed
battery box and cables/terminals for battery relocation-not installed.
K&N pod filter
A/m steering wheel.
Kenwood h/u, pioneer 4-way 6 inch speakers in doors, kenwood 6x9s rear.
Rw front bar(black), i hit a rabbit driving home and broke a chunk out of it, so zip tied it back together.
Type x front bar(white)-currently on the car-car will come with both front bars.
Nismo side skirts.
vented headlight cover
now for a few minor problems.
no rear seatbelts. got the buckles, but not belts.
minor scratches, dents around the car, bit of paint fade on the bonnet-all been there since ive had it, nothing that cant be expected of a 15year old car.
speedo is out by 20k. ive got an rsm, so dont use the dash speedo. may include rsm in sale, havent decided yet.
sunroof rattles a bit, but is fixable.
serviced every 5000ks. running royal purple oil and using genuine nissan oil filters. always run on BP ultimate.
it had a dyno tune before the rebuild and made 126kw on stock boost. i have a printout for it. hasnt been tuned since it has been built.
never been on a track or defected or had any other problems. ive owned it for about 2 years and other then over heating once due to blocked raditor it hasnt skipped a beat.
i have a folder full of receipts for everything thats been done to it, from the engine receipt right down to the wire used to wire up the gauges.
it will come with some stock parts, intercooler etc, and a bunch of other stuff, (unused battery box, turbo timer etc)
im sure ive forgotten some stuff, but ill put it up as i remember.
ill put some up to date photos up soon, but all thats changed is the front bar.
Images:
Edited by ted180
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/
should have no trouble selling this, we get inquiries for 180sx's all the time.
difficult to get them at a good price from Japan.
good luck with the sale!
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/#findComment-3487769
couple of things i forgot to mention;
either of the 2 front bars can be resprayed for serious buyer.
and i would like an R32 GTR, so ill accept swaps plus cash your way if you have one that suits me.
to keep this car as legal as possible ive done the following;
removed bov and replaced with stock piping.
removed turbo timer.
moved guages below the dash(legal).
only thing that can it can be defected for is coilovers. but with no bov or turbo timer there is nothing that will draw attention to the car, so getting pulled over isnt a common occurance.
and ive got hardcopy technical manuals.
Edited by ted180
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/#findComment-3489640
the owner of this car treats it like a baby, i can vouch for the fact that its well looked after. never thrashed, regular servicing and maintenance done. only tasteful mods and a nice looking car too! :D
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/#findComment-3491801
  • 1 month later...
  • 3 weeks later...
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 馃憤
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
