  • Replies 61
Yeah. That import site says they don't do RHD -> LHD conversions... You need to go to another place for that.
What does an aussie compliance include?
- Child restraints
- New filters / fluids
- New tyres
- Brake pad check and replace if necessary
- New Seatbelts
- The compliance plate
Anything else?
Given that tyres aren't included in the cost, I can't see why this costs so much. I imagine it would be fairly similar in the US, with maybe a MPH speedo conversion (even though my first car here had a MPH readout instead of KPH).
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-411623
Guest Chris Rodriguez
http://www.automotiveforums.com/vbulletin/...15&pagenumber=2
They argue it out here. Heard there are a lot of bumper safety requirements plus the emissions test. Supposedly it's one of the only vehicles you don't have to convert to RHD. It would be weird shifting with my left hand, but oh I'm sure I could handle it.
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-411714
  • 3 weeks later...
getting back on topic... I'm sorry to offend you Chris, but that product is just as good as the cyclonic fan that you chuck in your CAI pipe. lol its more of a hinderance than a benefit.
The dyno graphs you've got show a 3kw increase across the board. I know you guys don't claim any power increase, but theoretically speaking a responsiveness increase means a linear variation in the torque AND/OR the power curves. On your dyno chart both curves are exactly the same, one is simply higher than the other by a constant value... This means that your product hasn't increased responsiveness, its simply added 3 kw of power across the board, and likewise for torque.
Changing your oil regularly can do this. Why would any sane person want to spend US$300 (that's AU$600 lol I can turbo my car for that with a cheap ceramic turbo and a secondhand manifold and get maybe 10-20kw on an exponential rate) on the product when you can get a fuel regulator for much less which does a much better job of the same thing.
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-435457
A lot of cars would have to have custom manfolds made for their car. This is just not an option for everyone. I don't know when the new dyno graphs will come in. There have been a lot of different problems in different areas. One test that we just did is an airflow graph. Check that out...
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-435467
an HKS cold air kit (larger diameter steel mandrel bent piping, clamps and filters) for a typical car is US$170. The increase in airflow one of these would offer i reckon would be higher. Also just out of curiosity, why does it cost US$300 when the manufacturer sells em for US$139
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-435571
"why does it cost US$300 when the manufacturer sells em for US$139" The manufacturer is Lee Walker. He sells them for $350. I don't know where $300 came up. Anyways the flow of this is upwards of 800 CFM. The chart is on the website now. It compares the flow at certain voltages. To find out how much a car requires use this formula as stated earlier (RPMs x engine displacement in cu. in)/3456. For reference at 6500 RPMs a 4.6 L motor requires about 522 CFM.
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-435578
I'm going to remove the motor from my scooter and put honda V-twin off our whacker-packer on in. Then swing one of these bad babies off each side and screw boost up to 2psi with a powerfc with boost controller. Might have to mod the exhaust and re-jet teh carby tho' :D Should be fully sic bro!!
I'm just bullshittin ya's!
:(:):D
https://www.sau.com.au/forums/topic/19460-oh-my-god/page/3/#findComment-435789
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
