_bobo_ Posted November 21, 2007 Share Posted November 21, 2007 Im pretty keen on getting exhaust system done these holidays and i got a quote from an exhaust place in nunnawading this is it: Mildsteel ( i only plan to hold onto the car for about 3 more years ) 2.5 inch piping Mandrel bent hi flow cat oval muffler resonator cannon muffler all this for $700 (including labour&parts) + futher $120 to fit extractors with system so roughly $820 to get my setup done is this good or is there any cheaper places???? Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/ Share on other sites More sharing options...
_bobo_ Posted November 21, 2007 Author Share Posted November 21, 2007 oh also guy said that its better off if i find my own hi flow cat as he seen them around for 120 but if he gets them it costs about 220..so anyone got a hiflow cat Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488070 Share on other sites More sharing options...
r33cruiser Posted November 21, 2007 Share Posted November 21, 2007 wow. thats a bit pricey for only 2.5" and mild steel. if u check just jap and etc, u can get a full system for about $800-$900, which is abouts what your paying now. http://www.justjap.com/parts_nexhaust.htm Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488088 Share on other sites More sharing options...
_bobo_ Posted November 21, 2007 Author Share Posted November 21, 2007 yeah ive checked a few sites and other jap systems but couldnt find a nice one for around 700-800 with 2.5 inch piping only 3inch+....and the price i was quoted was 700 just for the exhaust....but i'll try and get a few more quotes. p.s...guy told me this will only give me about +4kw..what the hell i thought atleast 10-15kw? ohwel. Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488118 Share on other sites More sharing options...
GTS4WD Posted November 21, 2007 Share Posted November 21, 2007 A proper zorst wont give you much more peak KW.. but will increase power and rorque throughout all RPM ranges.. If you want a higher peak power.. and your torque and power throughout most rpm will suffer from this.. get a 3".. but your looseing all round more torque and power.. 2.5" is the goods Id say.. I dont think a hi flow if a must.. on such low power applications its gonna do didly squat And Stainless is better.. But thats my 2c.. Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488494 Share on other sites More sharing options...
_bobo_ Posted November 21, 2007 Author Share Posted November 21, 2007 so no point in hi flow cat... is there any difference between mild steel n stainles...all i know is that stainless lasts longer... Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488524 Share on other sites More sharing options...
R34GTFOUR Posted November 21, 2007 Share Posted November 21, 2007 (edited) stainless is only better cause it wont rust away in 10yrs, but i honestly think mild steel gives a better sound. It absorbs the resonance better and give a slightly deeper tone, which you want since yours is na. Theres nothing worse than a barking high pitched na exhaust i wouldnt expect a huge jump in power, but like gts4wd said there should be a noticeable difference across the rev range. If you opted for the extractors as well as a full exhaust then i would expect more than 4kw gain Edited November 21, 2007 by R34GTFOUR Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488534 Share on other sites More sharing options...
MissR34 Posted November 21, 2007 Share Posted November 21, 2007 Trust 3" Stainless Steel Cat Back Exhaust (a $900 exhaust) = 16.9 kW increase on my R34 GT Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488587 Share on other sites More sharing options...
GTS4WD Posted November 21, 2007 Share Posted November 21, 2007 (edited) Trust 3" Stainless Steel Cat Back Exhaust (a $900 exhaust) = 16.9 kW increase on my R34 GT Thats because your engine is VVL (Nissan's Variable Valve Lift and Timing) .. Different Cam system VVL varies the timing, duration, and lift of valves by using hydraulic pressure switch between two different sets of camshaft lobes. I really REALLY **REALLY** wanted an SR20VE bottom end and SR16VE in my pulsar.. Either that or the Jap spec X-trail came with an SR22VET.. but then I decided i valued my life.. =] Beau wont be getting the same out of his Rb25DE.. Edited November 21, 2007 by GTS4WD Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488603 Share on other sites More sharing options...
Eug Posted November 21, 2007 Share Posted November 21, 2007 Trust 3" Stainless Steel Cat Back Exhaust (a $900 exhaust) = 16.9 kW increase on my R34 GT just a reminder to others that the above stated power gain would be measured at max power at high rpm and does not represent the area under the curve (which i and many others believe is far more important in NA applications) also note that the Neo RB25 has VVL on both the intake and exhaust, so you wont get those gains on an RB25 Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488605 Share on other sites More sharing options...
r33cruiser Posted November 21, 2007 Share Posted November 21, 2007 true that! when i was waiting at maroochy exhaust centre, a guy with a civic wanted a 3" on there. and the bloke said "its not worth it mate, u go that big and u will lose all your torque" probably more expensive, because 2.5" isnt as common as 3", and is a n.a engine Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488867 Share on other sites More sharing options...
Eug Posted November 21, 2007 Share Posted November 21, 2007 "its not worth it mate, u go that big and u will lose all your torque" exactly... power figures are a reasonable standard for assessing the performance of an engine, but in no way does it describe the driveability of it. you are obviously exhausting/expelling more gases at a higher rpm and thus a larger exhaust would be beneficial to accomodate all that gas. however at low-mid rpm (where most people drive) all a larger exhaust will do is take longer to fill up with the gases to reach it's efficiency. it's a similar concept to "lag", a term often heard with people who mount large turbos to their motors. 2.25-2.50" is the ideal compromise for a non turbo RB street car. if you're a dyno queen or have a high/large power band and regularly see high rpm due to racing then by all means go larger. i do track work and often see 5-7000rpm and run a 2.50" exhaust. Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488899 Share on other sites More sharing options...
GTS4WD Posted November 21, 2007 Share Posted November 21, 2007 ..however at low-mid rpm (where most people drive) .. What if you drive in second everywhere? Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488969 Share on other sites More sharing options...
Eug Posted November 21, 2007 Share Posted November 21, 2007 What if you drive in second everywhere? then you better have lost 3rd and 4th whilst racing i'll accept no less Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3488982 Share on other sites More sharing options...
GTS4WD Posted November 21, 2007 Share Posted November 21, 2007 then you better have lost 3rd and 4th whilst racingi'll accept no less Well truth be told.. I had a drag race, ran too much nos and my passenger footwell welds broke and flew open.. This was before the laoptop flashed "DANGER".. Do you think I should get a 3" exhaust? Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3489058 Share on other sites More sharing options...
MissR34 Posted November 21, 2007 Share Posted November 21, 2007 just a reminder to others that the above stated power gain would be measured at max power at high rpm and does not represent the area under the curve (which i and many others believe is far more important in NA applications) also note that the Neo RB25 has VVL on both the intake and exhaust, so you wont get those gains on an RB25 sorry guys i keep forgetting i have the neo version engine og the RB25DE. my apologises. Eug would you like me to scan in a few of my dyno graphs so u can have a look at em??? Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3490023 Share on other sites More sharing options...
Eug Posted November 21, 2007 Share Posted November 21, 2007 by all means cara, i'm a firm believer that dyno runs are merely a quick and reasonable way to assess the potential of a car. the graph should definitely give some sort of indication as to whether or not your exhaust did give some benefit (a before and after would be ideal). by no means do i personally think it's a fair standard to use as many dyno ramp rates, settings, etc. vary, and even some dynos vary on the same day! i've had a dyno read my power output at 65rwkW and 10 minutes later 97rwkW and another 30 minutes later at 101rwkW. i don't even think that the dyno is THAT good for tuning, it's certainly effective for that though. i've always liked the concept of a road tune, as i believe cars are subjected to different loads and ambient conditions than under 'ideal' dyno conditions. i've just re-read the tone of my post, and hope it didn't come off as condescending or anything like that. i was merely pointing out to beau (the thread starter) not to expect the gains you achieved if he ever did get a 3" exhaust - he would be one unhappy dude wouldn't you think? Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3490043 Share on other sites More sharing options...
MissR34 Posted November 22, 2007 Share Posted November 22, 2007 but it is like getting extractors.............some will get a power gain and others will not............in my case , the car gained responsiveness but no actual power gain (despite leaving it for a month and putting it on the dyno). it depends on the car in the end when i was ringing around about clutches and flywheels, i was told that some cars do not handle lightened flywheels very well (i think he said BA falcons), while others, like the skylines handle the flywheels very well. i know ive probably just gone a little off topic! sorries!! Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3490104 Share on other sites More sharing options...
Eug Posted November 22, 2007 Share Posted November 22, 2007 i'm not 100% sure what you're trying to get at. extractors vary rarely do gain power, it's more of a torque/response thing as you create more efficiency in how the gases flow - you might see a slight power increase as it helps 'top end' a bit. you keep forgetting that power is measured at a specific rpm. for arguments sake; 300kW @ 9000rpm is useless for a street car, 200kW @ 3000rpm is different again. whilst the first one has more power, the 2nd one would easily be faster. skylines handle flywheels well, because they are a revvy motor by nature. they like to rev and the lightened flywheel enhances that. when comparing to a 4L V6 or a 5.XL V8 BA falcon they have the cubic capacity to generate the torque required to rotate all that mass. they are grunty like a tractor and wouldn't really need a flywheel unless they were high revving. take this dummy dyno graph for example... while one makes more peak power, it doesn't actually make that power until late in the rev range. the other makes less peak power, but makes more power on average than the other - and being in the rev range where people use it most, it's more effective in going fast. Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3490113 Share on other sites More sharing options...
R33GTS25 Posted November 22, 2007 Share Posted November 22, 2007 mate dont spend money on an NA R33... trust me you will regret it... since i got mine all i have done is put nice sounding muffler on it and a sound system... sounds good inside and sounds good outside Link to comment https://www.sau.com.au/forums/topic/194634-hows-this-for-the-price/#findComment-3490168 Share on other sites More sharing options...
