Detailers In Sydney
Swiper the Fox
 Share
Yeah I reckon so... I'm only taking up a day of his time, maybe two depending on what he thinks...
As for pricing, I'm not sure, but he does good prices for club members :rolleyes:
Do you have his number?
Thanx to all for the praise it is much appreciated :( , it makes me happy to help bring a desired quality finish to peoples cars & raise the bar on presentation of vehicles :D .
Looking forward to working some magic on the beast Paul see you soon champ :( .
And you to DrDoof, already to get yours sorted aswell. Your systems all done? Should sound pretty sweet :) .
I have to go do some wiring on it today, but it LOOKS finished... and in the end, isn't THAT what Auto Salon is REALLY about? :D
Good point you got there, I bet ya it kranks hard now right, cracked any glass yet?
www.spongenbubbles.com.au i found his work sensational
Name is too gay sorry...
Couldn't help myself there sorry. I do my own detailing and you can tell, it looks like crap.
I agree with Adam, I have to say.
If it was www.spongenbubblesnhotbikinichicks.com.au then I might consider using them, but seeing as it's not I'll be getting Jason to do my car in the not-too-distant future too.
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
