Just after a little assistance with a problem on my car, R33 GTST with a fresh RB26DETT conversion. Has been tuned on 12psi boost with Apexi Power FC DJETRO and full 3.5inch turbo back exhaust. Has been running strong for about 2 weeks but is displaying signs of a dropped cylinder.
Checked plugs and cylinder number two was significantly fowled up compared to the others, isolated it it to be cylinder number two by disconnecting the coil pack leads one by one, swapped in a new plug and then fired it up again and idled fine. Shut the vehicle off and took it around the block and started missing again. Swapped coil packs around and it was still on cylinder number two so it wasn't a faulty coil pack. Swapped brand new plugs in for all cylinders again and checked compression, compression was sitting around 135psi on cylinder 1 and 2 and 140psi for 3,4,5 and 6. The car is very sluggish and has a rough exhaust nte when on partial acceleration but once it gets past 3000rpm rev's smoothly to redline, I am suspecting a possible faulty injector, however am unsure, if anyone has had a similar issue please let me know what the issue turned out to be, any help would be greatly appreciated
Cheers Marty
i had pretty much exactly the same happen to me not that long ago. on cylinder two aswell, i changed plugs, and swapped the coilpacks around like you did. i couldn't figue it out.
i had not driven my car for a couple of months due to work being done and the battery was flat. the battery did hold a charge after charging it, but it mustn't of been enough because as soon as i tried a different (newer) battery the missing on cyl 2 went away.
My car was sitting for 7 months and the workshop through in a new battery so i know thats not a drama but yeah its got me baffled at this stage, my main concern was that the engine had expired but compression was fine, but yeah i am fairly certain that it is related to the injectors, as i have had a new Bosch 040 mounted in tank and all new fuel lines done with the conversion so fingers crossed its just an injector but only time will tell at this stage
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
