Nintendo Ds Lite Browser?
abu
 Share
Hey
Got my NINTENDO DS lite working on the R4DS chip and the games and themes are all working fine, but I am just having problems getting the browser to work.
The browser loads but after it loads it says;
"Press POWER or touch the check mark to power off, then insert memory expansion you received when purchasing your copy of the Nintendo DS browser"
Can someone help please, do I need to buy the wireless card thing for it to work?
Also, where do I load up music and video files to play on the DS?
Thanks,
Abu
Edited by abu
Need to buy the memory expansion of what of those 3-in-1 cards to use the browser. It needs more ram rather than space the R4DS won't give you that.
Ah I see.
Where can I get one and how much?
Nope you won't need that... your ds has an inbuilt wifi card. that card allows you (and three other players) to play other players on the net if you don't happen to have a compatible wireless router at home.
Ah awesome! Thanks heaps man, so confused with this shit.
So just the expansion slot I need, awessssome.
Now to find one hehe hopefully the place where I got my R4DS card from will have them, then I can just pick it up.
Thanks again man, big help.
Edited by abu
Awesome mate.. can you let us know how it goes when you get it? I might grab one for myself and my wife, would be good to use the browser when we're at gloria jeans or something.
Yeah will do man.
Been reading up while at work, seems like there is a little bit of work to get it working perfect with the R4DS, but its pretty simple.
They also come in black and white to suit your DS, so that’s good. And they sit flush, so it doesn't stick out.
Will let you know how it all goes once I get it, hopefully by end of next week if it all goes well
Yep I won't be using the wireless much, but a nice thing to have, pretty handy if you want to check up on your email when your out and about, plus you might as well utilize all the features
Edited by abu
Also interested to see how u go abu.
Where did u end up getting your R4DS from? Got links?
Howie, what card are u running on your DS'?
Hey
Yeah will post up results once I get it cranking.
Got my R4DS from this place: http://www.acegamestore.com/product.aspx?ProductID=519
Got my brother to pick it up and ended up getting it for $100, R4DS + 2gb Kingston Micro SD card & card reader, as well as the USB SD adapter thing.
They also post, 3 days I think it takes, free delivery.
Easy as to setup and get working.
bamboogaming seem pretty good, I made payment for the card yesterday and got an email just before saying its been put in the mail this afternoon, so hopefully should see it on Monday a I believe they are from NSW :wave:
Got my EZFLASH V card yesterday and finally got some time to play with it now!
Thought it would be plug and play, but its not! High hopes for something I knew wasn't going to happen.
Going to work out how to configure it now for the browser setup, if anyone else know let me know, saves me searching and fkning around!
Thanks.
wooo got it running!
http://www009.upp.so-net.ne.jp/rudolph/nds/3in1_ExpPack/
Download the first patch and load it onto the R4DS as it says.
Then simple load the 3in1 option, toggle through and selection what you want to use, eg: expansion, rumble weak, medial or strong and then you can select the browser from the games menu!
Some more info here: http://gbatemp.net/index.php?showtopic=67103
Let me know if you need help.
Edited by abu
Nice one abu! Thanks for the pointers. Let us know how you go with the browser/rumble stuff in a few weeks time.. i'd love to hear a mini-review of it.
No worries Howie, will write up a little review once I get a good chance to play with it lol
Played around with the browser yesterday, pretty cool and easy to use!
I can activate the rumble pack, but can't seem to activate it during game play. Need to read the instructions again and find out how to get it working/activate it during game play.
Over all so far though, its very easy to work and setup, easier than I thought to use.
Will keep you updated.
 Share
    • As someone who has been playing with turbo things for some time now, be prepared for this to not be the first time feeling this way    I'm busy as atm, but if no one else covers the things I'm realising are worth mentioning to you then I will when I have a chance as it seems like I overestimated your knowledge on how turbos and wastegates work.  Otherwise I recommend having a look around how wastegates and boost control work, really anything on understanding the general mechanism of boost control as it will help you find the answers to the questions you're looking for.  Your initial question jumps some fundamentals.
    • I don't understand anything anymore.
    • so this is an anomaly??? I thought it was a voluntary increase
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
