after initally wanting the stock spoiler when i was looking for my V35, i deceded quickly that i didn't like it at all. so i went for the no spoiler look.
a while back i finally decided i wanted a rear lip spoiler, and after searching on g35driver.com i found the one i was after
its from Unlimited Tuning, their G2 lip spoiler.. ordered in from the USA
well after recieving it a week back i finally had it painted and fitted today..
my first impression when i picked the car up was the mounting position. from the pictures i saw from g35driver, it is supposed to be mounted about an inch rearward than it is. i asked the painter and he said that this position is where it fit best over the bootlid and any further back and the front of the spoiler lifts up a little.. the colour is a great match and the finish of the painting is awesome upclose
to be honest i'm happy that the spoiler looks as i wanted it, but i'm a bit dissapointed with the mounting position
and to make things worst they used some kind of glue to mount it, the same thing they use to mount windscreens in place, so its not as easy as peeling it off and re-mounting it. i'm not sure of if or how they can remove it
i'm going to take it back tomorrow to get them to move it rearward however they can, i'm really quite dissapointed
well thought i would vent a bit and get some opinions while i'm at it and see if anyone has experience with this glue they talk of
cheers,
Warren
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/194692-m3-style-lip-spoiler-installed/
here are some pics from others that have installed it.. you can see what i mean by them mounting it more forward..
the red car is the one from their official unlimitedtuning website..
does anyone think that it looks ok where it is now, or am i right in feeling a bit dissappointed?
Sorry to say- they stuffed it BIG TIME. Does not flow at all.
i have a serious exam tomorrow for uni and i'm furious about the stupid spoiler.. hope i can get it out of my head before the morning
i'm going there straight after my exam and getting them to re-do it. if the urethane doesnt come off without scratching the paint i'm going to get them to re-paint the whole boot and they can pay for it
man its just been eating at me all night since i got home..
another pic of how its supposed to look is below. if you compare it to mine you can see how its supposed to flow and how mine is way off..
its partially my fault. they said they can't mount it flush with the rear as it doesn't sit right, and i said fine. i didn't think they would mount it half way up the boot though..
Hey Waz,
great idea, love those. But the definitely fu9ked it.
Worry about the exam first, car second. It's a spoiler, and even if they have to scrape it off the boot lid is re-sprayable.
Cheers
Bobby
bring it back and show them a picture of how it should be mounted.
good luck.
Hopefully the urethane hasnt set too hard.
Otherwise they will need to get a caramel wheel to get the remaining glue off.
Rather than run a bead along the whole way of the wing- 4 blobs should be enough.
apparently it sets in 4hrs to a good strength and fully sets in 14days
i'm going to take it in tomorrow so its as early as possible to make it as easy to get off as possible..
expensive lesson learnt for me - i think i'll leave the car as stock as i can for now..
just to update everyone..
went good on my exam :rofl: had a patient with a "borderline personality disorder" that i had to interview andmake a management plan.. not the easiest thing in the world
went good with the boot --> spoiler removed, no damage to boot or spoiler!
spoiler now for sale, and potentially already sold to Unique!
  • 4 weeks later...
I now have the same car as yours without rev cam but I am going with the clean no spoiler look.
Freakin love the car. Best ever.
G
went good on my exam :) had a patient with a "borderline personality disorder" that i had to interview andmake a management plan.. not the easiest thing in the world
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
