  • Replies 213
mIrc is still used but only by the geeky, many years ago now i tried to rally some enthusiasm towards a sau channel but it fell on deaf ears
If you could really be bothered with sau search engine look for irc and post made by user madaz you may find it :P
https://www.sau.com.au/forums/topic/194695-msn/page/10/#findComment-4788941
Well IRC is pretty useful for getting instant response for your question or at least thats what we still use it for in Singapore. Close friend or clique normally go on irc to just ask "anyone keep for a coffee at xxx?" instead of phoning each and everyone of your friend/ on your mobile.
https://www.sau.com.au/forums/topic/194695-msn/page/10/#findComment-4789430
Did i mention there is nothing wrong with being a geek, maybe its time for another lan ;)
Heh .. it always stuns me how many of my geek friends are into modified / japanese cars ..
... I'm just a cranky old netadmin/sysadmin/programmer type, getting a bit old for the whole LAN thing .. lol :)
https://www.sau.com.au/forums/topic/194695-msn/page/10/#findComment-4789479
  • 6 months later...
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
