sorry to have another 3076r thread.
before i ordered my 3076r i did some research and i remember someone saying that when ordering the IW option, make sure you get the over 1" size wastegate rear housing.
my rear housing is a .63 IW however the wastegate hole is 1".
drumaddict on here has the same turbo but on a rb20 and first testing shows that it has ridiculous over boosting problems...
AM I CRAZY??? or is there a wastegate hole that is larger than the 1" like i first thought?
i have the option of getting mine ported out with a new flap welded on for a couple hundred bucks... but realistically i'd prefer to get the correct exhaust housing like i was after...
thanks in advance
-Huddy
https://www.sau.com.au/forums/topic/194711-gt3076r-iw-sizing/
The M version has the larger flapper from garrett of which is ~$100 more than the std.
They do nothing more than port out the hole and then shove a larger flapper on it. So for a couple hundred get the same done from the local turbo shop. Its really not worth wasting $$ on selling and buying the M version. Get yours modded; its the same thing.
Then... Ensure you run a bell mouth dump; don't go with a split unless the setup/inlet flange section is the same as the HKS split dump.
If you want a pic of the HKS dump I have a pic I saved from a kind person who posted pics of the HKSGT3037ProS :)
ooh yes please post the pic up
i'm hoping that i can get it exchanged and only pay the extra $100 rather than get mine modified - as this was what i requested initially (specifically larger than 1", i just didn't state that is was the 'm' version...)
*waits for pic... :)
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
