sorry to have another 3076r thread.
before i ordered my 3076r i did some research and i remember someone saying that when ordering the IW option, make sure you get the over 1" size wastegate rear housing.
my rear housing is a .63 IW however the wastegate hole is 1".
drumaddict on here has the same turbo but on a rb20 and first testing shows that it has ridiculous over boosting problems...
AM I CRAZY??? or is there a wastegate hole that is larger than the 1" like i first thought?
i have the option of getting mine ported out with a new flap welded on for a couple hundred bucks... but realistically i'd prefer to get the correct exhaust housing like i was after...
thanks in advance
-Huddy
https://www.sau.com.au/forums/topic/194711-gt3076r-iw-sizing/
The M version has the larger flapper from garrett of which is ~$100 more than the std.
They do nothing more than port out the hole and then shove a larger flapper on it. So for a couple hundred get the same done from the local turbo shop. Its really not worth wasting $$ on selling and buying the M version. Get yours modded; its the same thing.
Then... Ensure you run a bell mouth dump; don't go with a split unless the setup/inlet flange section is the same as the HKS split dump.
If you want a pic of the HKS dump I have a pic I saved from a kind person who posted pics of the HKSGT3037ProS :)
ooh yes please post the pic up
i'm hoping that i can get it exchanged and only pay the extra $100 rather than get mine modified - as this was what i requested initially (specifically larger than 1", i just didn't state that is was the 'm' version...)
*waits for pic... :)
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
