thats so bad that they can just pull you up in another suburb and get you to follow them there, what if you had to be somewhere, i mean fair enough if you drive past and they pull you in, or pull you over on the road and defect you or sumtin. are they allowed to pull you up and just say follow me through a few suburbs so we can look at your car, sounds like harrasment or somthing
  • Replies 55
Sure can. Happed a fair bit last year. Even cars like 4GIVME got done in this way - was seen by other cars in same empty factories and such. I think they had one going off parra rd too.
The one in castle hill was a showground or something. Next to council building. Very dodgey.
thats farked, id be seriously pissed if that happened to me, its just wasting your farkin time, like at least an hour of it if you have to drive somwhere else, then what if your car passes, they've just wasted your time, what if you had somwhere important you had to be.
i heard about a guy today who was getting done by the EPA At brighton he got fined $15,000 Man id be killing myself right about now....
I ended up fitting a standard airbox it wasnt a GTR One but was one were my chrome pipinmg can get into.... went to the guy again at Granville He wouldnt pass it Because there wasnt Air flowing from the top of it through the filter into the turbos... This guy Man i swear is doing my head in..I cant wait until this is all over....
can you go to another guy, and also is this guy an old or young guy just out of curiosity?
probably in his 40s
this guy's own son's commonwhore (what else) was louder than my exhaust.....most of the car in his workshop is louder when they were moving them around....but i had to get mine passed !
he didnt even pass me when i rocked up with a full oem gtr exhaust! i ended up wasting $250 for parts and labour + $100 for him to pass the car with his fees (everytime you get tested you get charged!) and a couple of days off from work
one of the biggest rorts around i reckon....especially when there are only 2 workshops to choose from....this one or the one at Campbelltown.
what if you got smaller piping or anything like that between the turbos and intercooler, that will fit or that you can manage to bend around the stock box, then just find a way to disengage the turbos, so the pipes wont even need to run anything, drive it there and back, and your done.
BTW if you change the box is he gonna make you do another emmisions and noise test??
haha now u understand what i went through, but i got off lucky,
all this drama for a Fcukn Pod!
na na ive already passed the emissions test doesnt matter... I will have to do a noise test again because i am going cambeltown but i will pass beacuse ive put a stock box on now rather then the aluminium one which means less noise corect ?? well i hope so ???
Thats the dillemma i have the guy at granville only have to pass my filter box but the guy is a big d** head so im gona go striaght to cambeltown hopefully i get treated better there...
Edited by MRGTR911
If by "the guy at Campbelltown" you are referring to the Defect Notice Clearance Inspection Station, then i can shed some light for you. To me he appeared quite reasonable and approachable. I had been pulled over on Parramatta Rd and escorted to one of these make shift inspection stations in a industrial factory complex, at which point the examiner was overcome by the quantity of mods before him, Larger turbo's, pods, ebc, cams, cam gears (visible), larger FMIC, ecu, etc, so much so that he generalized the defect to read "all engine mods to comply with relevant ADR's & exhaust noise check".
I took my vehicle to TIC and had it engineered, covered the pods with an aluminium housing (painted black), stuffed a restrictor in the exhaust and generally hid the things i didn't want seen.
Went to the Campbelltown Guy, he took the engineers word for all on the report, no follow-up noise check, no probs with the enclosed pods, passed first go, defect cleared.
BTW every time i'm RBT'd i get asked to pop the bonnet, i produce the Engineers Report, engine bay checks ok, get hassled re noise (have since fitted HKS Silent Hi Power 95db), i assure them it gets quieter with rpm, rev engine to oblige and have thus far been allowed on my way.
Sorry for your pain, it annoyed the hell out of me at the time, i can only imagine what your going through.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
