no more fuel restrictors, since no more leaded fuel.
Assuming that all the parts are completely factory stock standard, and in very good condition, this is what needs to be done. (from memory, so I could be forgetting something)
add catalytic converter, brakes, oil, fuel, air filters, headlight conversion depending on the lights, head restraints modified, spare tyre sprayed mustard yellow, new australian chassis engraved, charcoal canister, full tune to meet emissions
any additions from some other compliance workshops care to help out?
The complete list that I do when compliancing an R34 is.
- Oil filter, fuel filter, air filter, new oil
- Headlights modified from the xenon globes to the H1's (if there nice, they can modify the headlights so it can be reconverted back to the xenon setup)
- 3 child restraits (some shops will only comply the R34 coupe's as 4 seaters so only use 2 restraits, GTR's are obviously a 4 seater anyway)
- Modify the drivers power window switch (to stop the window from being operated after the ignition is turned off)
- Cat convertor
- All new tyres with the proper DOT markings
- Genuine brake pads will need to be fitted if not
- Rotors at all correct thickness's with not too much of a large lip otherwise will need to be machined
- Brake line numbers must all have the correct markings
- Same with seat belts
- Various tests to be carried out to make sure emissions and sound levels are all correct
- Tint removed (if fitted)
- New carbon canister (whether its a nissan or aftermarket depends on the workshops evidence)
- Engine, unleaded and tyre stickers fitted
Also along with the fact of having all the standard parts fitted and in good condition
Remember that not all workshops have the same evidence for compliance but are all very similar
- Cat convertor
How much cost you for the modification to Australia standard?
For compliancing factory fitted dark glass is fine
Aftermarket tinting is not
And yes you will have to remove the tint before it goes over the pits
Cost for all the compliancing is different and depends on the RAWS workshop that is complying it.
If your looking for a rough price, check out this website
http://www.imports101.com.au
Just to clarify on this you're referring to the front driver and passenger windows and not the rear windows?
For cars like the Stagea which comes with 'safety glass' do they all make it through because the front D&P windows aren't tinted?
My wife's car (not a Skyline) allows the windows (all of them) and the sunroof to be opened or closed after the ignition key is removed, until such time the driver's door is opened. Then it shuts off the electrical supply. There are thousands of other cars that do the same.
So why is a RAWS/SEVS import different?
Cheers
Gary
Cheers
Gary
was it complied through RAWS or sevs? you wil tend to find alot of cars complied through sevs were half done and some wel basically nothing was done...
This must have been done to mine... how do i convert it back to Xenon type set up??
Not trying to hijack the thread but sum questions here related to compliance.
Can you compile a vehicle with a Blitz Nur Spec exhaust system on it or is there a need to rivert it back to the stock exhaust (please see attached pic).
Thks
It has to be complied with a stock exhaust on it, but we can let you borrow one for free if you comply it with us.
cheers,
david @ carizma
also, feel free to start a new thread if you'd like, I'm sure the moderators won't mind.
Thks
  • 1 month later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
