well here is a small comparison.
running exaclty the same still using the afm's for now (only for sake of comparison will be swapped out straight after) same filter everything.
this red line is the pfc (tuned by P.I.T.S) and the blue is the wolf v500 tune, which is not finished yet there is still a little way to go and to sought out why the power is dropping down so early. going to play with the timing and look at it possibly blowing out the spark (splitfire coils with 1.1mm plug gap)
throttle response is noticably better with a much smoother running motor. same power so far but it is coming on a lot earlier.
one issue my mechanic has noticed is it was running a bit rough (barely) when using larger mapping points. so we have dropped the mapping points down to 125rpm increments. much smoother.
post your thought people.
p.s. sorry about the quality, dodgy phone camera. cause scanner isn't working.
https://www.sau.com.au/forums/topic/194724-wolf-4500-vs-pfc/
The ECU is only as good as its tuner. :bunny:
Is this on the same dyno? Same tuner? Same day?
I ask because if it isnt, then its pretty hard (and pointless) to compare tiny differences in graphs like that. :)
The variance between the (many) factors of the dyno settings, air temp settings, tune settings etc etc are going to be more of a factor than the ECU itself which then makes it hard to same one "vs" one, this is better.
Its probably a case of the tuner spent more time on the tune, or leaned a bit more on the set-up than anything else... and that's solely attributed to different tuners (and tunes themselves), not ECU's because no two tunes will be the same if your changed the whole management. There is bound to be tiny differences like in the graph :D
different tuner however same dyno but different days. and yes the tuner has put more time into it, just merely pointing out that there is the possibility of putting more time into it i.e using much closer mapping points (125rpm increments) doing things like running twin maps (a future plan) just thought i would post it up for the hell of it. however once the wolf v500 is fully tuned then i will do a back to back comparison run as both are plug and play.
still more than happy with the power coming on a bit earlier up top. and like i said throttle response is noticably better. but then again the wolf is a more expensive ecu.
If there is more timing in one of the tunes, therefore they are not "the same".
Of course one will make more power than the other at various points with more timing, and this will attribute to throttle response as well.0
Could also be that the part throttle mapping has also had some extra work.
My main point is exactly as my first line earlier, the ECU is only as good as its tuner.
You have different ECU's, different tunes and different tuners... i would only be surprised if the results were the same :D
yeah i suppose. just let me bask in my ignorance for a bit longer. still pretty good results. here's another sheet form this afternoon after a bit more fiddling. cars almost finished. bloody mechanic still fidling with the tune just to see how good he can get it.
still more than happy with the results. going to fiddle a little bit more and try to get the power coming on a little earlier.
another intresting note is that more timing was actually fed in at higher rpm's as opposed to the general rule of thumb, more boost less timing. (still nothing compared to a n/a motor)
well that was kinda the plan but yeah not now. pretty much decided i am happy enough with that figure to not bother toying anymore. get the car back either today or tomorrow so i can't wait to take her for a drive.
i know it's not really a direct comparison. but it does (kinda) show how much further you can go with a better ecu. horses for courses though the PFC is a fair bit cheaper and a lot easier.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
