R35 Gtr - Costly Rebuilds At 100k - Fact Or Fiction?
I heard today that Nissan have chosen to Plasma coat the crankshaft in the the R35's and apparently they specify this needs to be redone every 100000km's. I also heard it will be very expensive and there are next to no workshops in Australia that currently use this technology regularly even though its common in the states. Was told it would almost be as cheap to buy a new motor? This was from a reliable source, won't go dropping names in case it turns out he was led up the garden path but yeah. Just wanted some thoughts!
In the current issue of motor magazine it states quote "3.8 litre twin turbo V6, featuring exotic materials such as plasma sprayed bores (requiring a tear down service program each 12 months!)" end quote. What does this mean? I dont know but if someone could shed some light on the situation it would be nice to know, sounds expensive though!
pretty much my motto on cars is;
if you can afford to buy it, you can afford to run it.
Yeah thats fair enough, but one would imagine that forking out over 15k for a motor at 100000km's is a big outlay. Id assume the motor would probably be a hell of a lot more then that to? Being titanium everything and technology that is completely new and previously unseen.
maybe its a 'PLASMA' tv in the dash that needs replacing every 100,000k's.
yeah go the warrenty make them pay for it, it's always more fun when someone else is paying for your cars problems.
this couldn't possibly be true- because to sell cars in California, the engine has to be able to endure a 120,000 mile (193,000km) durability test without a component change (apart from filters and oil) or rebuild, and still meet emissions regulations.
Sounds like someone has their facts mixed up. Plasma build up is a process used for building up damaged shafts / bores etc. We use it a lot in rebuilding big gearboxes (6"-20" diameter shafts). The ONLY reason it's used is because it minimises the heat build up during the repair process, and gives a fairly hard surface finish.
Note that it's only used in the repair process. The original manufacture relies on good old machining / surface treatment (induction harden / case carburising etc.). These shafts sell for upwards of a million bucks each. If plasma welding was so good, they'd use it when they built the things new.
Maybe the bores have some coating to reduce friction (because anything that improves hardness would give a better than 100,000km life, so I doubt it would be to improve hardness), but I doubt it's the typical plasma build up process.
Edited by warps
Would this plasma coating be referring to a type of coating in the bores that has been used on 2 and 4 stroke motorbikes for years?
Ive had a couple of bikes that use a nickel/silicone coating in the bores thats applied by plasma when manufactured. The coating is extremely hard and therefore has zero bore wear, unlike conventional cast iron bores.
maybe the bores are coated in teflon :rofl:
wheels and motor magazine journo's couldn't accurately describe the mechanics of a horse drawn cart let alone a car.
Yeh I've heard of the Nicasil process (First came across it on a mate's go kart engine in 1984, so been around for a while). Didn't know that they applied using the plasma process though. I've only dealt with plasma welding / spraying of ferritic material to build up worn components.
I guess they might be using something similar to the nicasil, but it astounds me that the engine would need a rebuild after only 100,000km with this stuff.
Was reading here http://press.nissan-global.com/PRESSKIT/NI...LISH/index.html (go to MECHANISM then ENGINE)
where it says instead of cast sleeves in an aluminium block, the unsleeved bores are plasma coated instead (0.15mm instead of 2.5mm sleeves). Better heat transfer, less weight, yada yada...
If this need maintainence every 100k then holy crap thats a bad idea!
Ya, when they talk about plasma coating the bores it's the same as the method they use on motorbikes. I can't remember where I was reading it, it had nothing to do with the new GTR but talking about doing it to car engines. For the reason you stated, less bore wear, but I doubt it would have to be redone every 100K I thought the whole point of it from the article I was reading was to extend engine life.....
This sounds like a crock of shite. Some people only do 5-10K per 12 months, let alone 100,000Km which could take 10 years. Like people have said above aussie journos writing crap to fill lines on a page.
maybe the bores are coated in teflon ;)
Of course they could! First, shoot the horse. Next load the horse into the cart. The say 'what was the question again?' :D
haha this is funny shit
honestly, i know what you read, but think about it logically..
why would nissan make a car with so much R&D in it but make the engine expire in 100,000kms?
logic is a great thing sometimes.
(what i'm trying to say is its all a load of shite)
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
