There's plenty of components that could be helping out there.
It does sound suspension related if it is ok unless going over bumps.
Might be time to change the bushes or something like that.
Pretty cheap if you just install pineapples to make it tight again.
Check for wet or oily patches in the general area around the subframe.
If it isn't suspension related, perhaps something simple like a tailshaft bracket has come loose.
Or it could be something dodgy like your exhaust is hanging loose.
Either of these rocking at high-speed would amplify the effect of the wobble.
Depends what you are feeling. Wouldn't hurt to take a quick look to rule these out.
You should be able to give it a decent overview yourself - from gearbox back.
Try and shake everything by hand and if anything moves, that'd be the first place to start.
Once the initial check is done, best to get it onto a hoist and give it a proper look, especially if it is influencing hi-speed control like that.
Should be easy to rule out wheel bearings if you aren't hearing the low hum noise at high speeds.
If you drift, then who knows.
Might just have to take the trusted mechanic for a spin and see what they think.
Oh - Does it feel like your suspension is bottom-ing out ? Perhaps just need a new set of springs, or if there is oil running down your shocks, perhaps time to get a new set of those.
Hope this helps.
Don't mean to hijack or anything - related really - but what the hell are pineapples and what exactly do they do?
I have heard about them, seen pics of them but just lost on where they go in the susp. and their function...
Seriously just take it into one of those pedders suspension checks... Cheap and your not obligated to have any work done afterwards.
Probably the quickest way to find out what the issue is because as above it could be numerous things.
Thanks PappaDuck for all your help.
I can rule out anything being loose now.
The car has got pineapples.
When I think about it more I think it is suspension related.
The front end has to tendency to bottom out going over bumps and makes a loud bang noise.
If i remember corrrectly it all seemed to change after one drifting eposide. Mates have told me the rear tyres look wobbly and it kinds feels likr that a bit aswell.
I'll put it on a hoist and see if i can find something wrong with suspension.
mine is doing the same thing. are you hearing a sound like something is hitting something else. like metal to metal, my left rear strut is blown and as soon as it went out mine started hopping left. its scary feeling. check and see if your struts are good. im replacing mine and ill let you know if it fixes it. also yeah what are pineapples
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
