Make:nissan
Model:late 1998 r34 gtt skyline
Milage:26700klm
Transmission:manual
Colour:midnight blue
Currently registered? yes 7 months rego
Price:$21900
Contact:0422172482
Comments / Modifications: nismo front bumper,
factory xenon headlights
clear front indicators
rear red foglight like on gtr
tinted windows
hks coilovers
19x9.5 impul starcorp rims with fat dish!
front mount intercooler with polished piping
full 3in cat back exhaust (awesome deep sound)
bosch 040 fuel pump
blitz super sound blow off valve
blitz air filter
blitz boost gauge
full car alarm with immoboliser and turbo timer
momo steering wheel
razo gear knob
r33 gtr seats
blue l.e.d globes in dash console and centre gauges
car made 197 rwkw with power fc but have sold it seperately
i am the 2nd australian owner of this car and have had it for nearly 12months.
i bought it with 18000klms on the clock and it now has 26700klms. ive had it serviced only at
belgarge and autsport using only royal purple oil and nismo filters. just had a service at 25k at
autosport and they said the car is in perfect mechanical condition. this car is a real headturer and will not dissapoint!
All inspections welcome
willing to take off parts for a cheaper price i.e, wheels, coilovers, exhaust, seats etc.
so if any one has the standard parts pm me with your offer.
if you have the standard wheels and seats will sell car for $19500
Images:
Edited by yld_33r
https://www.sau.com.au/forums/topic/194741-rare-midnight-blue-r34-gtt/
  • 1 month later...
I was looking at this car myself about 2 years ago back in Jan 2006 when i was looking around for an R34. Pretty neat car honestly. I still have pictures of it :(.
Unfortunately i'm going to sell my 34 as well :D. Good luck anyway.
would u mind selling ur split/dump pipe? Also will take the front mount as well if ur planning on selling them sepaerately ;) ?
yeh mate am willing to sell them, im just going to leave it as is for another week or so and see if i can sell the car as is, if not i will be returning the car to stock.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
