  • Replies 116
bump, more parts added/updated, split things into groups to make it easier to read
Chassis has subframe, rear window, rear quarter windows, would be good for a rear cut or something
Also has engine plate/compliance plate, car not listed as a writeoff or anything
$500
or $680 delivered via tow truck to your door SA metro only
if not off to SIMS metal or similar
Hi I am chasing a drivers side rear QTR window and shipping to Darwin.
If you can cut it out let me know a price with shipping
Regards Devo
$500
If I have to cut it out myself I'd want $90 for the driver rear quarter window this is including delivery to you in Darwin
need to act soon may be going to wreckers this Wed
hi im interested in cluster surround wot does it include pic preferably i will forward 20 bucks ur way is it a series 2 cluster
bank details
Hey man just wondering if you had this clip?
sorry sold rear wiper and motor today, brakes are not for sale
shell looks like it's been sold now as is
cluster surround is just the plastic piece that sits in the dashboard in front of the cluster (ie surrounds the front of it if you get what I mean), comes with screws, all parts from a Series II (the actual cluster/odometer has been already sold)
Hey, was wondering if you'd split the interior trim so I could get just the driver's side A-pillar trim? Mine's got some rather horrible holes in it from the previous owner installing a boost/AFR gauge.
the A-pillar I have also has 2 or 3 screw holes in it, make an offer
seriously if you want me to split gear up make on offer, my prices are up there as is and some bundles are fair cheap already, if you need things broken up then make an offer at the same time
sorry front windscreen smashed
ok would u be able to send it to melbourne give me bank details and tell me wot i should put on the remitter and i will pay
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
