  • Replies 116
still have parcel shelf, excellent condition, no mark/sholes
sorry don't think I have it, reckon I left it on the engine in the end, if I can find it I'll send you a PM
just ? did you find it?
nah sorry definitely don't have it
do u sell only the lhs only..?postage available included with the price..?
thanks
LHS only is $80
or the pair for $120
postage is $20-25 Aus wide
recieved everything fine n its all in, cheers mate, pleasure doing dealings wit ya :)
no worries, I asked them to put fragile stickers on it....needed a bit of a custom box or should I say 3 boxes to send it!!!
re: alarm PM sent
Hey PT you want to sell me the RH rear tail light for $60 and $20 freight to QLD? Looks like vince88 wants the LH so between me and him we have split the pair.
Edited by shajar
if both sell at once for $60 I can do it but only on that condition, vince88 never got back to me, otherwise $80 for the RHS
or you can buy both and sell the other one yourself
Hi mate, do you still have the ashtray? If so would you accept $20 inc. freight to Cairns QLD 4870?
Also looking for the plastic part of dash under the steering wheel, the part your knees hit.
Edited by shajar
How much for the fuel cap and postage to Perth?
$10 for the fuel cap
postage is $5.30 normal post or $7.40 express post
sorry ash tray sold as has dash, stereo surround and centre conslole
the other plastic piece you refer to, if it has a fuse box cover on the left of it then I'm pretty sure I still have it
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
