As a few guys may be aware I went to the east coast of the US for 5 weeks and dropped in at the SEMA show in Las Vegas on the way back. For those that may not be aware, the annual SEMA do in Las Vegas show is the biggest automotive aftermarket show anywhere in the world. Over 25,000 exhibitors means that it is impossible to see everything in the 4 days that the show is open for, you just hit your personal highlights. I had penty of those, considering that I brought back over 12kgs of brochures and catalogues.
Over the next few days I will attempt to load up some of the 300 or so pictures I took at SEMA and add a few details on my observances. This being the SAU forum, they will be mostly Nissan related with an emphasis on the new stuff that I saw, some of it for the first time.
Hope you find it interesting.
Cheers
https://www.sau.com.au/forums/topic/194795-nissans-sema/
Nice one Gary!!
Look forward to more shots!
Im guessing its around OctoberNovember each year?
Mrs and I are thinking of heading to the US in 08....might wait to Sema then :D
The 2nd photo...n00b question.. is that a Primera? (sp?)
https://www.sau.com.au/forums/topic/194795-nissans-sema/#findComment-3494164
Nice one Gary!!
Thanks
There is a few (phew) more to go
Yep, usually the end of October, early November. Next year is Tuesday, November 4 to Friday, November 7, 2008
The SEMA show is trade only, so make sure you register well before hand. You can't just turn up.
www.semashow.com
Nope
Cheers
Gary
https://www.sau.com.au/forums/topic/194795-nissans-sema/#findComment-3494325
350Z's are huge in the US, cos the Z33, the G35 and the RX8 are the only decent RWD japanese sports cars they have available to em atm.
we're kinda spoilt for choice with 2000 - 2002 model R34's, RX7's, S15's, Supra's etc.
I doubt the 350Z revolution will hit Australia as hard as it has hit the US, where its now being used for circuit, street, rice, drift and showpony use. That said there's heeeaps of parts from the US and japan available. 350Z's are oddball in japan... there's lots of parts and support, and lots of tuner built demo cars, but hardly any that are built up on the streets.
https://www.sau.com.au/forums/topic/194795-nissans-sema/#findComment-3498292
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
