hello, i just got my R33 BNR33 and it is slightly modified with fmic and hks bov, lighten fly wheel, racing clutch and fuel injectors. I am a newbie to turbocharged car and there are a few questions that i need to seek advice from the nice people here. Below are my questions, would appreciate if anyone is kind enough to answer my questions.
1)I do not have any aftermarket oil pressure, boost level or oil temp metres on my car, can someone enlighten me what are the normal value for these readings on the R33 dashboard?
2)I installed an IES GSM alarm on the car, ever since then my turbos are giving some sort of a grinding sound whenever the rpm is below 2k. It sounds like the fins are "spinning and gridinng on something". It sounds normal at higher revs(3k and above). Is this normal?(The sound is most noticable from 1.8k to 2.8k rpm and pick-up seems to be slow, at 3k boost everything is fine and i can feel the boost)
3)what is the stock turbo for RB25DET?
4)What kind of metres should i get for my skyline?eg:voltmetre, boost meter,oil pressure etc (not for show offs, just want to make sure my car is healthy)
5)when they say change their fluids, eg: brake fluid, oil fluid, lsd fluid, bla bla bla, what kinda fluids are there to look for?(sorry, complete idiot here)
boost: at the line between 0 and +7 at full boost (+7 = 1bar = 13.8psi)
oil: around 3 on the standard gauge when warm and rising to about 3/4 way or 7 at high rpm and quick rising rpm.
stock turbo is T3. good for 12psi max.
main thing to have in ur car would be boost only. keep and eye on boost spikes if u up the boost.
fluids to change would be oil, transmisson, power steering, brakes too. only when necessary. service the car regularly with the same mechanic and hell be able to keep an eye on what is needed.
with regards to ur grinding noise, its got me stumped. if it was the turbo it would have blown if it was rubbing on the housing. grinding noise could be a rubbing tyre on guard liner or soemthing more than a turbo issue. get a workshop to look at the car. one that understands turbo's.
Mate if you dont know what the noise is. get it checked out asap. the way you describe it, its hard to pinpoint what it is. im guessing it may be from the gearbox, or your turbo is stuffed.
The oil pressure guage on the dash in a lot of skylines is very inaccurate. I recommend buying boost guage, oil pressure and oil temp. water temp if you want but the rest is for people trying to show off to their passengers.
as for fluids, try doing a search on this site to see what other people use in their cars.
grinding noise sounds like what i have between 2 and 2.5k rpm one every gear
its related to the driveline somewhere but don't know where exactly, either clutch or gearbox is my guess but a few mechanics have heard it and said its not to worry about.
Boost feels better at 3k coz thats when the turbz is starting to get a move on, under that and it feels gutless
I'm taking a stab in the dark and say he's hearing the really high pitched squeal noise. And it occurs not on boost but rather in vacuum at a certain vac point.
It sounds kind of like microphone feedback.
If its this sound your hearing, don't worry about it.
Edited by KeyMaker
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
