Hey all,
thought i would post my experience with whiteline swaybars.
All parts were correct for the vehicle.
Fitted the front on a hoist in under 30mins, popped exhaust off, removed rear, went to fit it and it wouldn't line up...
My mechanic fiddled and got it on, but we then were disappointed with the design, to tired to explain, but they have got the link binding the bushes against the bar to stiffen it up, and it will chew the bushes. I spoke to my mechanic, and they normally get custom ones made properly for the race/rally cars, with a swivel in the end of the link...
The car feels looser, but sits flatter. On the up hand, with whiteline camber/castor bushes, the front end felt alot better until i put the bars in, and my rear tires are no longer being chewed.
Wish i spent the extra $100 per end :)
-Ryan
https://www.sau.com.au/forums/topic/194821-whiteline-swaybars/
That dont sound too good...
so which parts would you recommend? Would you say the camber/castor bushes were worth it over the stock items?
And my impression from your post is that the whiteline swaybars, whilst making it drive flatter, actually make it worse to drive ??
Just wanted to clarify in case I ever get the urge to upgrade any of this stuff. :)
I reccomend their bushes. That is it. gonna track down some nismo springs, or go custom.
i got the bushes installed yesterday, best upgrade possible for a stagea, camber/castor and thats it. the swaybars were a waste of money.
I will try and get comparison photos next week, big rally this weekend so could have trouble getting hoist time.
Here are my findings:
After Bilsteins- Felt good
After Whiteline camber/castor bushes- great turn in, front end felt 'tighter' more steering feel, slightly heavier steering.
After Swaybars- possibly sits flatter, car feels 'sloppy'
I'm going to put some KM's on the car, then if i don't like it, will be selling the whiteline bars and going to stockies and spending the money on the datto.
-Ryan
hey Ryan .. I am very interested in discussing this ..
I was going to get the swaybar so that I could get a bit of the body roll out of the Stagea .. but now your saying they did SFA for you?
well... not really SFA but 5/8ths there of :wave:
have you gone thru all these suspension changes in an orderly manner? cause sometimes chaning manythings at once leaves you a bit confused as to what made what difference ( if that makes sense )
can you define " sloppy" is that more in the fact that you still have a good amt of body roll?
just out of curiosity what profile tire you running? lower profile will give you a harsher ride but it will definately give you less roll in the corners.
May I ask how much the whiteline camber/castor bushes set you back ?
-Ryan
the Whiteline 'adjustable' front and rear swaybars are one of the BEST mods you could do
well, I stick by that anyway....... an awesome upgrade IMO
edit: I use Bilstein shocks, standard springs, Whiteline adjustable swaybars, Whiteline front castor and rear pineapples
No body roll to speak of, great handling, very smooth ride, turn and point and accelerate
After i installed the front link and rear adjustable camber arm. I ended up getting -2camber in the front and the rears went from -2.69 to -0.5. The car felt very nice. More road feel, shrper steering and the rear grips when especially in windy roads. Took the car out for a drive to melbourne through toobrack, lancefield kilmore way. Very nice!!
thanks everyone .. I am going to start getting a bit more in the know abotu these things
the handling of the stagea as it is leaves a bit to be desired.
Okay, gotta be quick coz i'm ment to be converting the back of the stagea into a bed...
Fitted bilsteins first, defiantly worth every cent. Using standard springs.
Fitted Bushes day before yesterday, everything felt BEAUTIFUL, turn in was great, general 'feel' was improved, the poly replacing the old rubber amazed me, front felt superb.
Fitted swaybars yesterday, rear on softest, front on softest, front end feels like it has shit bushes now, aligned today by traction tires, they did a good job, recommend them highly. Took it for a short drive, unhappy with the bodyroll, doing 800km this weekend, so will assess it, if i have time, half way through i will stiffen up the front bar, will report back next week. Talking to the guy at traction(manager, great bloke), we discussed it and the general dynamics of what the car is doing, he agreed with my conclusion: Return to stock bars, get custom springs and shocks valved to suit. Probably keep to pretty much the same specs as whiteline springs, just better quality. Might try and track down some Nismo S-tech.
The Design of the whiteline bars uses the binding up of the bushes/links to cheaply stiffen the car/hopefully reduce bodyroll. This hasn't given me a good effect/feel, and i will review my decision to return to stock after this weekend, but right now you can tell what i am thinking. Also on the topic of whiteline design, they used shit quality fittings, as with all swaybars i have bought i will be going to a 'bolt barn' type joint and replacing all nuts/bolts with high tensile items that properly fit my sidchrome spanners.
The only reason why i am considering aftermarket springs is because lowering with the circlips reduces tire/wheel clearance.
225/50/16 Bridgestone RE001's, tested 38-42psi hot pressures on various days, and now stick to 40psi warm. I have always played with tires on the 16/r31's/stagea.
If anyone wants low KM swaybars, PM me :D
Cheers,
-Ryan
Edited by Ryan1600
BTW, rear end feels nervous so i wouldn't recommend soft rear/soft front, i would go soft rear/stiff front as Gary recommends, but I personally prefer to start off soft and stiffen it until i find the sweet spot.
Hi Ryan, let's work through the issues one by one;
I am not sure what you mean by this. The bushes rotate around the crush tubes, the crush tubes prevent overtightening of the bushes, so there is no possibility of binding.
You would have to go below the recommend height (345 mm rear) for the lower spring seat positioning to be an issue. If you do go to an aftermarket spring please be carefull in your choices as nothing I have found off the shelf suites the Stagea's balance. That includes Nismo.
Have a look at your toe and camber settings on the rear, I have tried all the combinations of bar setting and I have never ever felt any nervousness in the rear. Try a little toe in (2 mm each side) if you feel the necessity, but I would be surprised if you do
car feels 'sloppy'
You haven't mentioned what sized bars you have , but I assume they are the sizes as recommended in the Group Buy. Fitting the rear 24 mm bar has increased the rear roll stiffness by over 100%, that is the important end with a Stagea (waggon, high CoG + low roll centre = big roll couple). The front roll stiffness is around a 50% increase, any more than that and we end up with a tad too much understeer. With that amount of roll stiffness increase, I am not sure how you can describe it as "sloppy".
I have been fitting upgraded swaybars to my own cars for over 30 years, I have yet to find one single car that hasn't benefitted from their fitment. In a customer car sense, I have only ever had one car that sufferd when upgraded bars were fitted and it had the hardest tyres I have ever seen. Put a decent tyre on it and it was fine. So, you are either feeling for something that isn't there, perhaps expecting too much of reduction in roll or there is something wrong in the product selection or their fitment.
There are over 30 Stagea running around with the Group Buy kits fitted to them and I have had nothing but positive feed back. Even Duncan (who races an R32GTR) was pleasantly surprised at how well his Stagea handled the SAU track day at Wakefield Park. I am always willing to help, so feel free to contact me anytime.
Cheers
Gary
Gary, Traction Tyres in Rowville did the alignment, i told them the settings you mentioned and mentioned your name, he knew of you and did it off of that... couldn't get enough of my rear camber out(still have -1), but he explained to me the dynamics of IRS and why i shouldn't go for less. I might try and change the front bar to the hardest setting now.
-Ryan
-Ryan
hei ryan whats your front camber like? mine is -2 rear is 0.5. Feels great although the steering its a lottle bit sensitive.
REAR: L R
Camber -1.04 -0.56
Toe +1.0mm +1.4mm
Front
Camber -1.05 -0.51
Toe +0.3mm +0.2mm
Castor +5.16 +5.13
when i can get back in with craig will play with it following exactly what gary said with the front bar stiffer, then go from there.
REAR: L R
Camber -1.04 -0.56
Toe +1.0mm +1.4mm
Front
Camber -1.05 -0.51
Toe +0.3mm +0.2mm
Castor +5.16 +5.13
Why is your left side have more of everything? purposely did it? On my rig before i installed the components it have more of everything on the right!! LOL!!
ok, I waited a year and a half prior to doing a wheel alignment
(only just had the front castor fitted)
settings:
Front caster: Left 5.29 Right 4.33
Front camber: Left -1.19 Right -1.18
Front toe: Left 0.4 Right 0.7 Total 1.1
Rear camber: Left -1.57 Right -1.27
Rear toe: Left 0.5 Right 0.9 Total 1.4
Thrust angle: 0.02
I am very happy with the handling
Stock springs are perfect: simply siad, aftermarket springs ARE NOT NEEDED when using the Bilsteins and circlips for lowering
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
