WWW.ISC-PERFORMANCE.COM OR WWW.ISC-COILOVERS.COM
Just thought I'ld throw up some pictures of our new S13 silvia that I will be using for local comps etc. Purchased the car about 5 weeks ago and have since had it resprayed by Doyles and had a few more goodies fitted. Car will be tuned soon at Boostworx and will hopefully hit the 200rwkw. The car will be used for local comps in SA and basically as a general promo car for ISC.
-S14 T28 Turbo
-GTR Injectors
-ARC FMIC
-RB 20 AFM
-Remapped computer "BOOSTWORX"
-GTR Fuel pump
-Full exhaust 3" with a Tomei Dump pipe
-Boost controller
-NISMO 1.5 way LSD
-ISC Coilovers
-5 Stud Conversion
-R32 brakes all round (That included drum handbrake on the rear)
-After market Clutch
-Braided Clutch Line
-Bracing behind the front guards
-Cusco Strut Braces Front and Rear
-After market Steering rack, has an unbelivable amount of lock around 70 degrees.
-Lower control arms for more lock
-Buddy Club Bucket seat
-GTR Passenger Seat
-Cusco full cage
-Boost Gauge
-R32 Radiator
-GTR Rear Swaybar
-Solid Pineapples
-Adjustable Castor Rods
-Adjustable rear camber arms
-Adjustable rear toe arms
-Non hicas rear subframe
-Vertex fron/sideskirts
-Rear bar unknown??
-Vented fibreglass bonnet
-Origin style c/f mirrors
-17 x 8 +10 work vs-xx wheels
Edited by ISC-Performance
https://www.sau.com.au/forums/topic/194827-isc-drift-s13/
GO RYAN :PBJ: :PBJ: GO GO :PBJ: :PBJ: GO RYAN
Looking the bloody goods mate, hopefully the ol C banger goes alright for ya, wont be anything like the 26!! Oh well if she goes bang then a 20 will fit snug in there too!!
MASSIVE ISC Stickers required!!
Looks like it has a sr20 by where the rear spoiler was.
Looks great!
https://www.sau.com.au/forums/topic/194827-isc-drift-s13/#findComment-3492834
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
