As topic states i have a set of 18" shadow chrome rims with small dish for $800 $750
rear wheels have 40% tread
front wheels have 80% tread
CONTACT
MSN : [email protected]
MOBILE : 0404 109 739 ( If No Answer send an SMS ) NO PRIVATE NUMBERS
Edited by tekniquez
https://www.sau.com.au/forums/topic/194836-18-ozzy-tyres-revo-rims-750/
http://www.ozzy-tyres.com/page.php?load=wh...&mag_id=195
not sure of offset coz it aint printed on the back ..
but for the fronts .. the rim would hit the brakes .. after 6mm of spacers .. i could only turn the nuts twice on the studs and i cant be bothered getting longer studs, already got a new set of rims.
Edited by tekniquez
will they fit a r33? if they do i can probably pick them up on sunday.....5 stud....
not sure man it also depends if u got bigger brakes, coilovers etc i have hks coilovers thats why it didnt fit.
yes i am the one who had the wheels fitted to my car, fitted nicely but you do need 3-5mm spacers on the front and maybe on the back,they barely touch the caliper without the spacers, very nice rims by the way and in excellent condition.
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
