HKS Vcam controller...its a variable cam timing controller...is it yours??
are these things very effective on straights?? i understand around a track they can be very handy though
dude owns a GTt
not for long buddy.................not for long :D
also how much are these things worth? havnt seen these around the aust market
Edited by R34NRG
https://www.sau.com.au/forums/topic/194848-what-is-this/#findComment-3491752
HKS V CAM System STEP 1 typeA ¥406,560
Intake camshaft, valve timing unit, intake side head cover (black), valve timing controller (Pro type), oil control solenoid valve, sensor and other fitting parts. 248 degree 8.6mm intake camshaft. 30 degree adjustability (90~120 degrees). For use with normal pistons. 99/1~02/8.
HKS V CAM System STEP 1 typeB ¥406,560
Intake camshaft, valve timing unit, intake side head cover (black), valve timing controller (Pro type), oil control solenoid valve, sensor and other fitting parts. 248 degree 8.6mm intake camshaft. 50 degree adjustability (75~125 degrees). For use with HKS forged pistons. 99/1~02/8.
$4,290.75 AUD @ 94.7526JPY plus shipping, duty and gst
Source: Greenline
https://www.sau.com.au/forums/topic/194848-what-is-this/#findComment-3492581
the HKS VCT has been reviewed in 1 of the jap import DVDs (RB Japanese Muscle) and they had a HKS demo R34 GTR and did a few laps with VCT on and they say you could feel is more responsive with VCT ON, however it did not shave much time off the final lap times compared to no VCT...
Im just wondering is it worth that much money ? And then you have the good tuner problem as mentioned before...
https://www.sau.com.au/forums/topic/194848-what-is-this/#findComment-3493003
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
