i recently got my turbo hiflowed by gcg, did the whole shebang, injectors,fuel pump, pfc etc..
took it for a tune at Unique, and it turns out that i cant hold boost. they swapped over a r33 gtst actuator and added tension, and according to them, there was a slight improvement holding boost.
they also patched in a profec b ebc, and upped the gain to max, and it held boost much better.
from the graph, you can see:
on high boost, 18psi drops to ~13.2psi
on low boost, 13psi drops to 10 psi
the guys at unique cant figure it out (im sure they would eventually, but i cant afford to keep dishing out money :D)
so im looking for some insight/experiences someone might be able to share.
atm, im looking to upgrade the actuator to a hks adjustable, and also looking into putting in a avcr boost controller.(currently have a dual stage turbo xs boost cont.)
but if i can get some advice before doing that, i can spare myself some cash!!
what do you reckon??
Edited by bikey
https://www.sau.com.au/forums/topic/194853-r34-with-gcg-hiflow-problem/
The hks actuator will not provide you with anything that the profec b won't handle. Not at 18 psi anyways.
Cars i've worked on using the usual standard actuator + avcr or profeb b, etc etc all can usually easily hold 18 psi flat.
There is some other problem.
This may sound silly, but try dropping the exhaust. I.e. just run the turbo straight out into the air.
the exhaust heat is too hot... can you imagine the heat generated in the engine bay? lol plus, i dont think any workshops will let me. (ive asked a few)
btw, ive got a split dump pipe running 3 inches throught the front, cat, catback...
and yes, got a Trust FMIC happening...
Edited by bikey
Ok, another option that i've seen with some gcg highflows and other highflows - the catridge is shorter, which means that the wastegate flapper leaks. But i'm guessing that unique already checked this - when you said that they added tension (by bending the rod)
his exhaust isnt restrictive. its got a trust front pipe, hiflow cat and a 3" cat back. his exhaust flows.
its just that on the dyno whenever its given a boot, no matter if its on high boost or low boost it loses around 4psi.
i was having a read about the GCG turbos, when they weld on the wastegate they weld it on with the wrong angle so when you put your wastegate actuator on it makes the wastegate flap open slightly. thats why the extra preload (tension on the wastegate arm) would have helped.
ive got a similar problem with my gcg hiflow and ill be putting a bit of extra preload by bending the actuator arm a bit.
manwh0re, i reckon you should try this too if your turbo isnt stuffed. i remember you telling me that you used to start seeing boost at 4000rpm on your slide hiflow. it may be a similar fault.
Look at eliminating the cat as a restriction point.
$30-40 should see a 3 inch pipe with flanges welded up, and then you're not wasting workshop time and paying more $$ dropping pipes off etc.
If you do a search under a thread by Al, you will find he experienced some high flow performance issues that ended up being exhaust system related.
FWIW, the graphs themselves look quite respectable at the boost levels being achieved (namely dropping).
Joe, already did it from the start :wave:
very similar with my slide highflow
I ended up using a cheap 3rdhand GFB stealthFX plumback BOV (helped a little IMO) and awaiting my HKS heavy duty actuator from Nengun, who certainly arnt in any sort of rush to post it out to me
Im hoping the actuator will help me hold the boost better than what it was when tuned.
Is your intake the factory rubber one? perhaps its sucking closed on boost ??
And don't waste your money on fully sick boost controllers, just get yoursself a turbotech one, doesn't spike etc..
I'm using one and it holds 16PSI all day lonng
i'll put it down to the hot side being to restrictive, causing high back pressure on the manifold side of the turbo and forcing open the wastegate.
how much power do you think can be put through an op6 turbine housing, its designed for standard power, sure the highflow wheel will help, but only so far. if you want every last bit possible, get it power ported as well.
a 1 bar actuator might help a bit, but that will become your lowest possible boost setting remember.
hi bikey i had the same issue with my boost dropping at high revs on my high flow ,tuners were stumped until i saw the rubber intake pipe sucking close at high revs, read this it has solved my problem
http://www.skylinesaustralia.com/forums/Lo...87#entry3458787
Edited by OVADRV
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
