Just want some advice on what i should do for my first engine upgrade on a 1996 R33 gts-t. i was thinking for now purchasing an intercooler and getting it installed. Dont want something too expensive or too cheap, just want something good for now, what brands does anyone recomend. is there something i should do as well or should that be it for now, cheers.
https://www.sau.com.au/forums/topic/194858-intercooler-upgrade/
34 s.m.cooler
apexi safc
front pipe
high flow cat
boost controller
cat back.
in that order
:D
search through here for some diy tips: http://www.skylinesaustralia.com/forums/Tu...IY-FAQ-f57.html
oh and make sure your 100k service is done too
Edited by toffy
im in the process of exactly that atm :D just not in that order.
catback
r34 smic
frontpipe
cat
boost control
safc
well everything except catback and smic is actually gonna go on at once, after i find a good boost guage and the labour cash
Get your exhaust and intake system sorted first.
A larger intercooler and larger diameter piping will result in a drop in response on a stock car.
Bring up the boost a little then think about an intercooler.
Not really needed though for anything under 180-190rwkw.
well i got a 33 as well but i done these mods and i was pulling out on stock boost without the front mount about 180 rwkw....so my advice is to do this:
* full turbo back exhaust system
* a high flowing pod or pannel filter
* clutch if its manual and you do give it a bit
* splitfire coilpacks
* trust/greddy front mount intercooler theses days sell for around $600-$700 with piping
i got a few more mods planned but not as of yet
im in the process of exactly that atm :wave: just not in that order.
catback
r34 smic
frontpipe
cat
boost control
safc
34 s.m.cooler
apexi safc
front pipe
high flow cat
boost controller
cat back.
in that order
DONT FORGET THE DUMP PIPE. www.gktech.com.au has dump pipes for 100$, and fronts with flex pipe for a similar price.
-Ryan
get a hybrid kit for r33. about $650 or so from traders on these forums. Good quality cooler, without the price tag of some of the jap ones. Trust kits are good also and not that expensive. I personally think that a r34 cooler is a bit of a waste of time to be honest. Just do i right from the start and it will give you plenty of head room later on. HPI had an article on modding a 33 gtst including the cooler upgrades, was a couple of issues back. worth looking at.
Thanks guys, the advice was really helpfull
cheers
Unless you are planning on upgrading the factory turbo, I would recommend against a front mount. I made the mistake before, it's not necessary on the stock turbo and you will notice a definate loss in response from the factory setup.
As suggested, an r34 side mount is the way to go.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
