Do you have a front mount? pull out ur plugs and see if they are fouled..
If you cant be bother get on the highway and launch it to try burn off anything on the plugs.. you will prob have to change them soon. when you do regap them to 0.8 - 1.0 somewhere about there.. unless you up the boost then keep it at 0.8
Nope.. no front mount....
I can see the Nth bound off ramp at the tuggerah exit on the F3 from where i live so i will get onto the freeway and see if that does anything ... spose i may as well change them whilst im there.. looks to be a pain in the ass job!
I can get double platunim NGK plugs for $16.20 plus gst each.. that a good price??
I just use regular NGK's round $6ea. All Iridiums do is last longer, they dont perform any better, there's plenty of threads bout plugs if u search. Just make sure u gap them correctly for the boost ur running.
Edited by G_Force
  • 3 months later...
i know this post date is well after the last one but for any future referance.
it's not TCS that is the problem it's the O2 sensor i had the same problem above 4 000rpm under load major problems tacho would jump from like 4 000- 7 000 rpm randomly the engine was not even doing that much.
week or two later engine light started coming on (only when warm cause that is the only time the O2 sensor does anything) got it checked at work sure enough O2 code was there.
yea car still has the problem.. and its over fueling something shocking. Im going to get a EL 02 sensor and see how that goes.
Im not driving the car that much atm so im not too concerned about it all.
