Hey guys,
Been having this problem for the last few months now and it's seriously giving me the shits. I'm running a stock ECU (for the time being until i get some money together for a Microtech) and a HKS GT-RS turbo (list of other mods down below). Now the problem is with boost. Boost comes on nicely up to 0.5bar at about 2500rpm or so, then it very slowly goes up to 1.0bar at 6000rpm. From 6000rpm to 7000rpm it starts skyrocketing up to about 1.5bar. Im pretty sure if i didnt have a revlimiter it would keep climbing in boost.
Now i've read hundreds of threads on boostproblems/boost creep and a lot of people have problems with this so i've tried all the logical things that it could be:
1. Actuator: It's HKS one set to its longest point which should be 14psi, however when disconnected and the flap is wired all the way open it still makes boost, at about 4000rpm it kicks is and once again nearly up to 1-1.5bar, it goes so quick i cant tell the exact boost it reaches. So it's not actuator related.
2. Dump pipe: Boost control is sometimes altered by the setup of the dump pipe, either it sucking the flap open, or keeping it shut. Now i used to have a split BOS importing dump pipe and it used to do it, now i've changed into an all in one bellmouth X-Force dump pipe and it is still doing it. So it can't be the dump.
So everything points to the standard ECU either retarding the timing that much that it is somehow affecting boost, no idea how this could work but it's the only thing i have to go on. Has any one had any experience running a bigger turbo on a stock ECU. Is the change of plenum and turbo too much for a stock ECU to handle?? I really hope the Microtech will solve it, but if it doesn't im still going to have this problem. Why won't it hold 14psi!!!! And why does it take so long for it to reach 14psi?? It's like it's doing 2 opposite things, taking ages to make boost, then suddenly making heaps of boost.
Any help or input would be great.
Thanks :wave:
https://www.sau.com.au/forums/topic/194910-stock-ecu-and-bigger-turbo/
earth your standard boost solenoid, if it fixes it, then read thru Sydneykids jaycar thread, and there is a photo showing how to re-route vaccum hoses.
Warning, check with a mechanic first, this might only help if your current wastegate setup is identical to stock bar the adjustment.
Well you shouldnt be running 14psi on the stock ECU anyhow.
Why it takes so long, probably because the stock ECU is shitting itself and retarding the timing from 4000-5000rpm.
Again, this is due to you running more boost (airflow) than the stock ECU accept in its wildest dreams.
So IMO. Put the stock actuator back on till you get a ECU.
Then go looking for issues with response etc etc
In all honesty your playing with fire with that setup
use a safc as a temp messure until you can afford the full ecu
Tried that, tuner said he couldn't tune it because of the amount of the boost skyrocketing. Looks like ill just have to get the Microtech ASAP.
So you agree that it's all in the ECU and that once the Microtech is in it should fix it all? This is the only thing that i can pinpoint it too. When you say im playing with fire, can it do much damage running it like that on the stock ECU? Like other than it running rich and retarding the timing, it doesn't seem to be knocking and aslong as i dont keep it above 6grand it doesnt overboost, so should it be allright for a little while longer? I'm looking at the microtech within the next month or two.
    • Each province differs a bit but we only do mandatory vehicle inspections here for heavy vehicles (Think Ford F350 and up). Those inspections are done by mechanics that are approved by the government. Besides that, it's a free for all as long as the car looks stock.  I asked because I love seeing how engineering differs from country to country. Here in Canada, all designs must be stamped and signed before they can be brought to fruition. (I.E Bridges, structures, Electrical panels, machines, literally everything shy of a wooden table) This can only be done by a professional engineer or professional engineering technologist. Both are protected titles, but the latter having more of a limited scope in what they can stamp. To become a professional engineer, you must complete a 4-5 year bachelors degree in your field of engineering, be part of an engineering order and undergo 4 years of apprenticeship, testing and mandatory continues education. Same story for engineering technologists, but a 3 year associates degree in some form of engineering technology will suffice. If you do not comply, or pretend you're an engineer or technologist, off to jail you go. If you stamp a design that fails, off to jail you go. If you stamp a design that fails and kills someone (I.E Bridge collapse) Off to jail you go for a very long time, your family will be ridiculed on the news, neighbours will surround your home with pitch forks and your dog will disown you.  Same for specialised trades... Example Electricians must undergo 1.5 years of post high school education, 4 years of apprenticeship, testing and hold proper licences. It's for the best, but then we also wonder why we're so short on engineers and tradesmen haha
    • Not currently, I'm at the school where we teach people to build bridges and other fun things that involve making, or breaking things
    • I have a friend who has used Chequered Tuning and CMS. Went to CMS when Chequered had a long wait time which is kind of the norm (for good reason). Was very happy - I'm pretty sure the very simple thing you're asking will be simple.
    • lol that caught up a year quickly! good to see you on the track again, hoping to do it myself one day
    • Nah he was mega organised, the sort of guy that put (almost) every tool back every day, it made trying to work out where things were up to possible.  My shed needs a swedish death clean, I would have >20 part done jobs, its particularly hard to collect all required parts for a job ahead of time when you can't just pop into a shop and grab things
