hi guys. just wondering if anyone has done the whole, water spray on the fmic and radiator?
i was thinking of running it off the window washer resoviour with a small motor, than splicing it into 2 foggers, one for fmic, one for radiator.
i need some inspiration and ideas.
anyone done it? :D
This is a DIY IC spray done on a Z32. Guess you could use the same principles.
http://www.pexcom.com.au/z32cms/e107_plugi...php?content.315
Do skylines have the rear window washer? if they do maybe you could take the line that goes to the rear window washer and reroute it to the IC.
another good mod would be to make an air guide to force air through the fmic. otherwise air will hit the FMIC and just go around/under it.
there's some good info in this thread: http://www.aus300zx.com/forum/showthread.php?t=261337
these pics are from that thread. the pic below is of the Unique Autosports Slotcar.
And this is what another member made.
all i've done to get my car ready for summer is replace the upper hose with a new stock one, replace the lower hose with a alloy hose (stock rubber can be sucked flat under extreme thrashing = no coolant into engine), radiator rodded & flushed and put new toytoa red coolant in.
Edited by Sandeep
