  • Replies 232
ok guys there's roughly another $1232 to collect before this group buy goes ahead
i would like it if you can either deposit money into my bank account or ring, txt me and organise payment 0421932750
i work @ Beverly and travel to TTG so thats a fair whack of suburbs i can collect money from
once these last payments are in we can start getting our cars tinted
Steve
Steve, do you know if we are supposed to clean the windows ourselves before the tint is put on. IF so what do they recommend. Also, 3rd eye brake lights are they to be removed from the rear window before tinting.
How is it looking getting the dosh from the remaining ppl to get this rolling? I;m starting to dream of tinted windows atm. Which doesn't seem normal at the best of times.
need to hit pauly kye kellie, there 3 definite's not sure about martin hopefully this week but not sure sort of out of my hands
he didnt say about cleaning windows so i would assume he does that same with brake light
Ha ha gold.
As for cleaning windows my mate used to tint windows for a living and he would praise people that did some of the prep work themselves, saves them heaps of time. I will take my door trims off and clean the windows before I take it in, saves them 15 minutes or so per car.
Cheers
Edited by harvesteros
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
