I have a emanage ultimate and also got the GTR wiring harness that just plugs straight in. i have the diagram that shows how to mod the harness to suit GTS-T. Just wondering if anyone has done this before and if it all works ok? bout to do the mod as my car goes in to be tuned in a couple of days. Also where have you mounted the unit? cheers
https://www.sau.com.au/forums/topic/194941-emanage-ultimate/
interested to know this also. i did the mod on mine, cut the wires etc.
plugged it all in hooked up the laptop updated software, set all the engine parameters but could not get the car to start.
if you get yours working please take some pics so i can see how you have modded it to make sure i have done mine correctly.
i was just gonna get my tuner to install it, but if i can get it sorted before then that would be awesome.
good luck :D
yeah because it only alters the signals from the stock ecu it is fine to drive. because if you dont change anything in the maps its just the same as having the stock ecu.
mine just wouldnt turn over and i flatened my battery trying to get it to work, so i havent been assed to try again
I had the simialar problem me and mad082 did the chnage over at my work and it was a pain in the arse cause we had it going then it died. check and make sure that all of the pins line up and the harness is in the properly as for mounting it I was going to put it in the glove box but had other stuff in there so i put it under my cd player .
ok modded the harness just before and plugged it in. the car sounded like it was bout to start but didnt. my car goes to tuner first thing tomorrow morning so ill get him to have a look at it. very curious as to why it didnt work. any thoughts would be much appreciated.
thats exactly what mine did, started to crank but wouldnt turn over. if you find out whats wrong be sure to let me know cos i cant figure it out :worship:
yeah i couldnt figure out the pin changes on the board, from what i could see i assumed they were correct so i left them standard?
am i supposed to change these for a r33 using the plug and play harness?
uras this is aimed at you because i used your wiring diagram :)
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
