R32 Was A Bigger Step Forward Than R35
  • Replies 64
Let's try something a little interesting.
There seems to be some guys with the opinion that this is an "automatic" gearbox and one day it will come with a "manual". My opinion is this is a "manual" because;
1. It has a clutch, in fact it has 2 clutches
2. It doesn't have a torque converter (that's very important)
3. Not having a H pattern shift is irrelevant, sequential shifting is still "manual" in fact plenty of competition cars have sequential gearboxes, World Rally Cars, Champ Cars, Super Tourers and, next year, even V8 Supercars.
4. Just because there is the option of not changing gear yourself doesn't make it an automatic
5. Just because it doesn't have a clutch pedal doesn't mean it's not a manual. The clutch/clutches is/are actuated by other means, so what? A V8Supercar has an ignition cut on the gearlever which serves the same purpose, cuts the ignition momentarily so you can change up a gear without using the clutch pedal. Except they aren't as "smart" as a GTR, you still have to use the clutch pedal on the down change.
5. The gearbox is one of the reasons why it is so fast, in a straight line and around the track. Because the shift speed is much faster than you and I can manage with a clutch pedal and a H pattern shift. There is almost no pause in the acceleration, no loss of boost.
It's a manual in every sense of the word, arguably the best type of manual. Something the R32GTR would have benefitted greatly from, that's why sequential Hollingers are such a popular upgrade for track cars.
Cheers
Gary
I'm kind of with SK on this.
My definition of a "manual gearbox" is a a housing full of gears that has to be selected manually. Its not called a "manual clutch", so how the clutch is operated is irrelevant to the definition of the gearbox. It doesn't matter if it uses a torque converter either - how a gearbox does its thing is a matter of implementation, not definition.
I'd call this kind of gearbox a "semi manual" since it gives the driver full control of when the gears are changed in the appropriate mode. If you look at most Euro "Tiptronics" those things will change gear for you when you reach a certain RPM in their "manual" mode, even without driver intervention, which in my books makes it "semi automatic" instead.
Yeah i totally agree too. This is a manual gearbox. and like I've said earlier taking away the clutch pedal just means you can't miss a gear which is great for a race car - you also can't select the wrong gear (which is good news for motors, right tacker :))
This reminds me of people claiming gearboxes with synchros weren't real manuals either. Not many gearboxes in cars without synchros these days
Yeah, but people like that were probably born around 1890, and are no doubt all dead by now
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
