  • Replies 44
I would assume it would be slightly me responsive being ball bearing as opposed to journal (kkr items are journal bearing type are they not?) ...
also aren't the kkr series only oil cooled whereas the HKS item is water and oil cooled??
if I could have my pick I would have anything HKS put on my car over anything else on the market :D
Don't get me wrong, I love the japan stuff, but he already has the bigger KKR. A 2530 won't make the same power. It's considerably smaller. If we're talking a comparable Jap turbo you'd be looking at something the size of a 2840 or a GT30 I would think?
only making around 295rwhp
yes its laggy bout 4500rpm full boost
the car with 2530 on it i took it for a drive last nite, very good low down torque and mid range wheel spins coming on in 2nd but yeah
i dunno wot to do lol
help me!!! some ppl say 2530 2 small for rb25? im only really after 300rwhp would 2530 get me there easy enough?
well the motor has 250,000kms on it and ive been running 19psi thru it for last 6 months
so 300rwhp is pretty much the limits i think and response would be nice my thing is laggy as hell haha its a joke!
obviously you're unhappy with your current lag and you've seen the down low response of the 2530. whats holding you back?
250000kms? wtf juz?
295RWHP@19psi, with fully boost at 4500rpm = VERY SHIT TURBO!!
For a turbo to make full boost at 4500rpm i would expect it to be pretty damn big and make at least 330rwkw (450rwhp)
Kkr's aren't shit ..
however the kkr430 would have been the better option... unless you want to use it for just drags etc. it's not going to get great response with a stock engine,
John Cane runs (drifter) runs a kkr430 on his Rb25det in his laurel and it goes awesome!
Read specs here > otomoto
Edited by RB_turbo_bitch
I had a HKS 2535 which is a little better but I have been in an RB25 with a 2530 on it and there is almost no lag! It was an awsome street car the only downfall it had was that you couldnt push it to redline you were better of shifting at 6 - 6,500 rpm...
I would do it.. it will make about 220 - 230 max but i have seen them run mid 12's in an R33.. PM Robo's on the forum, he had one.
Its not all about rwkw.... from how laggy you have said your turbo is, the 2530 would destroy the kkr setup on the street even if it was making a bit more power.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
