you are invited to the next antrx.com cruise
Guest 91nismotrx
 Share
Guest 91nismotrx
new carpark? huh? hehe :(
its the same carpark that was always decided on, and trust me there are plenty of car parks there, enough parking for 100+ cars, and i dont think we're gonna need that many..
  • Replies 55
well i think if u lot are gunna do a cruise in the future set it up 100% before u move. i am extremely disappointed with ur efforts! as i was there for an hour and not many ppl showed up to my eyes so i left. i'm not haven a go just giving u lot some ideas.
uh...... no cars from SAu turned up?
We waited until the specified time, and then left.
There were TRX's, R31's, a GTiR, and some other assorted cars...
I don't know where the two of you waited........ but it must have been either the wrong place, or the wrong time. ;)
Originally posted by 91nismotrx
you can enter by the myob entrance on springvale rd or by lakeside drive/wesley crt off the burwood hwy.
melway ref is map 62 C7
meet time will be 10:30-11am on july 20th with an 11:30 sharp departure.
obviously people cant read. It was THAT hard to find at all... I'm form the west, found it in a second.
:shake:
I think you guys went to the burvale... not the proper meet point mentioned above ?
well if people were friendly and helpful with directions and things i would've been in the right spot! i asked for help a few times and everyone turned and looked the other way. i'm still very disappointed. i waited at the burvale carpark to see if i could maybe catch a few skylines and follow them, but i didnt see any. thanx people for not helping.
Take a breather people
Obviously some misunderstanding.
Lets get it right for the next cruise (GOR, Geelong) ;)
HOPE TO SEE YA ALL THERE!!
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
